Results 1 to 20 of 22
Thread: cam is done!!
    sick & twisted SS 02_slp_ss's Avatar
    Jun 2009
    Chambersburg PA
    2002 SS camaro
    cam is done!!
    well i got the cam finished this morning around 130 lol. it sounds nasty i love it. almost everything went good. had a couple problems but i worked them out, big thanks to mark for the tools i would still probably still be doing my springs. now i just need a tune. but im very happy did allbut everything by my self mark help on a couple springs.
    Member importhater81's Avatar
    Oct 2009
    chicagoland,Il
    02 ss camaro
    Post a vid of the car running with new cam!
    Member jeffsWS-6's Avatar
    Winchester,CA
    BLACK
    2001 WS-6
    want to hear it!
    Jun 2009
    Chambersburg PA
    2002 SS camaro
    ok boys ill try, its raining today so after it stops i will, how u put vids up on here
    mercersburg pa
    hugger orange
    2004
    hey glad to hear you got the car back together! lol told you that pickup tube bolt would be the hard part.
    mercersburg pa
    hugger orange
    2004
    does your car sound about like mine now?
    Jun 2009
    Chambersburg PA
    2002 SS camaro
    well the car wont even run now it misses really bad
    LSwut tep98ws6's Avatar
    Jun 2009
    Saint Louis, MO
    Arctic White & Black
    '98 WS6 M6 - SWAPTIME!
    Quote Originally Posted by 02_slp_ss View Post
    what kind of cam do you have? some cams change the firing order which makes it sound real funny ... and the longer you wait on tuning it, the chance increases of fouling a plug. my cam changed my firing order and it sounds goofy. and i agree on video
    congrats, btw
    Jun 2009
    Chambersburg PA
    2002 SS camaro
    congrats, btw
    well i got the MS3 cam, a baby cam compared to yours lol, an when i got done a started it, it sounded awsome i let it sit an idle for alittle an get warm then took it for alittle drive pulled in my drive way an my raditor hose split so i fixed it this morning started it up an it sounded fine THEN it started it was missing so bad it was idleing smoth lol crazy i no but it was, i called the guy who tunes my car an we talked about it alittle an think it might be loading up so where going to put a tune on it an see what that does. i might have to get a new set of plugs to idk yet
    Jun 2009
    Saint Louis, MO
    i am having cooling issues too i cracked a coolant line under the intake and my water pump gave out. i'm probably gonna do plugs too. it's been run probably 1.0+ hours since the rebuild, not fully broken in and definitely not tuned yet so the fuel mixture is all weird and im probably just killing off plugs left and right
    videooooooooooooooo
    Jun 2009
    Chambersburg PA
    2002 SS camaro
    lol yea i no what u mean i just went out an bought a new set of plugs to try an see if it helps, an idk how to put a video up lol
    mercersburg pa
    hugger orange
    2004
    Probably fouled the plugs bad. It sounfds strange, but idle and low rpms it will need A LOT less fuel than before, but it will need more fuel up higher
    2000 Camaro B4C
    congrats on the install, i hope you figure out whats wrong so we can hear that baby run
    You got an MS3....it doesn't have a tune...and you wonder why it won't run??
    Really?
    Tep, did you change anything in the shortblock?? I don't remember what all you were doing. If you didn't, there is basicly no break-in period for valvetrain components...aside from heat cycling the valvesprings 2-3 times.
    And for further reference...the MS3 is MUCH larger than the cam Tep put in. (at least if it got the 231/231 .621/.621 112)
    Jun 2009
    Chambersburg PA
    2002 SS camaro
    Really?
    ok i got little more duration 237/242 but shes got more lift thats y i said that.
    an yes i no i got an ms3 an it needs a tune but i dont think it shouldnt miss like it does. i no at low RPM u need alot less fuel, but i still think it should run alittle better then it does. Am i wrong? idk im just lookin for help.
    It did this to me befor when i put my LT's on an 3 coils went bad on the right side of the motor
    Member BlackSS1's Avatar
    Lexington, NC
    2001 Camaro SS Vert
    I installed a significantly smaller cam than yours this past summer, and it ran like total crap until I got tuned. It would not hold an idle, misfired, shook the car, and threw misfire codes from the computer, etc. You need a tune bro
    Jun 2009
    Chambersburg PA
    2002 SS camaro
    ok man i figured i did i thought it might run alittle lol guess not
    MS3 cam, harland sharp 1.7, pac 1518 sprins, ported 241 heads, LT, 3in E-cutout, Ram stage 2 clutch, 13 lb fly wheel. << 443rwhp 451rwtq>>
    mercersburg pa
    hugger orange
    2004
    When I put my 1st cam in (220/224) it fired right up and ran till it got warm... Then kept dieing and ran VERY rough... And it was a baby cam, luckily had hptuners on the laptop in the garage and got her straitened out pretty quick
    Member jb3golf's Avatar
    Zona
    1998 Camaro Z28 Conv. M6
    Good job bro!!!! I know exactly how you feel!!!!! I JUST finished installing the whole deal: Heads, Cam, LT's, Rod bolts, Sway Bar, ALL suspension parts + drill/slotted hi performance rotors and pads.......Aren't YOU proud of YOURSELF!! You should share your thoughts of the start up on my thread reference the moment of truth.........it's a long road........congrats.....
    Zona
    Quote Originally Posted by mark21742 View Post
    Interesting.......mine started right up also (thank God) Idled on its own, and hasn't given me any issues since.....its a 224R TSP ........I NEED a tune now!!!
