Results 1 to 20 of 30
Thread: SES Light flashing
09-11-2008, 06:23 AM #1
- Dec 2007
- Arkansas/Missouri State Line
Collector Yellow- 2002 Pontiac Trans Am CE
SES Light flashing
Yesterday, I noticed that my car was running really strange. It started up just fine, but after my drive to town for work it began running really choppy. The car's stock by motor standards, and no kind of motor work has been done to it in the recent past. It has 30k miles on it and about fifteen minutes ago it began running really bad.
I started the car up, and within five minutes of being on it was at a running temp of 160. It normally takes about ten minutes for the motor to completely warm up. The SES light was going on and then off, but then it began blinking in threes.
Then it ran extremely rough, and surging between 300-900rpm's. The light flashed faster and I was experiencing heavy exhaust fumes, which the car rarely does. The fumes smelled strongly of gasoline, so I turned the engine off.
Any ideas as to what may be happening to my car?
UPDATE 9/16/08*
The car is throwing these:
P0200 - Injector Circuit Open
P0200"pd" - Injector Circuit Open
P0308"pd" - Cylinder 8 Misfire Detected
10-9-08 - RECEIVED NEW CODE
PO155 - 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
I'm seriously at a loss here, and I'm not able to tow it to a dealership due to the loss of my job.Last edited by SS/CETA; 10-09-2008 at 02:04 PM.
09-11-2008, 06:37 AM #2
Sounds like a random misfire. Can you pull the code and post it up? Check your wires to ensure they are tight and not melted, could also be a fouled plug, your best bet is to pull the code(s) and post them up.
09-11-2008, 06:39 AM #3
- Apr 2006
- Charlotte, NC
Hugger Orange/W stripes- 1999 Z28 M6
I can't tell you for certain what the problem is, but I would recommend you unhook the battery for a while (an hour or so), and then hook it back up. Let the computer re-think, sometimes that's all it takes.
09-11-2008, 06:40 AM #4
- Jul 2007
- most miserable city in the US
blue green chameleon- 1998 Trans Am
im clueless but i would try and find someone with a scanner so you can see what codes the engine is throwing. i wouldnt drive it till you do, you wouldnt wanna cause any permanent damage. if you do get a scanner but it doesnt define the code just post the code i have a thing to define them. good luck
09-11-2008, 06:44 AM #5
09-11-2008, 06:59 AM #6
- Dec 2007
I've got a few buddies with diagnostics tools, so as soon as I find one of them to run it on the car, I'll let you know.
09-12-2008, 11:24 AM #7
- Dec 2007
UPDATE*
"P0200: Injector Circuit Open"
There's the code it threw. So I'm guessing I have a stuck fuel injector, hence why the exhaust is healthy with the stench of gasoline?
09-12-2008, 02:40 PM #8
- Dec 2007
I honestly need help with this. It's my daily driver and I'm completely clueless to the LS1 engines. ANY help would be greatly appreciated.
09-12-2008, 03:12 PM #9
Go to #2 injector which is the very front on the passenger side and make sure it is plugged in. Take a look at the wires to it and make sure no critters chewed the wires. If they are good try GENTLY tapping on the injector(while it's running) with something like the butt of a screw driver or an extension and see if the problem goes away.
09-16-2008, 02:25 PM #10
- Dec 2007
Edited at top with the thrown codes I'm receiving.
09-16-2008, 04:39 PM #11
Woops, I thought it was a po202. Anyway, it sounds like an injector problem but it could be a wiring problem (to the injector) also. I guess what I would do is try to pulse the injector (with the car off). With out any diagnostic equipment I guess you will have to use jumper wires to power and ground and see if you can hear a "click" Or take it to a mechanic so you don't set it on fire.
10-09-2008, 02:05 PM #12
- Dec 2007
Updated @ top with a new OBDII code found today, 10-9-08.
10-09-2008, 02:25 PM #13
well as for the Ho2s code that you got 2day that is traditionally a bad o2 sensor. just replace it. did you ever get the other driveability problems fingered out?
10-09-2008, 02:57 PM #14
what troubleshooting have you done, you haven't said...
your injector has failed, or the wiring to it is broken somewhere along the way.
10-09-2008, 03:01 PM #15
^^^ yeah i forgot an open on your injector circuit doesnt mean the injector is stuck open, it means the circuitry is open/broken
10-09-2008, 04:23 PM #16
- Dec 2007
That's what I needed to know. My daily is an LT1, and unfortunately for me I've not studied the LS1 as much as I should have. I've tried erasing the codes and unplugging the battery, to which neither work.
10-09-2008, 04:35 PM #17
- Oct 2007
- CANFIELD, OHIO
PEWETER METALIC- 2002 CAMARO Z-28 M-6
Time to replace the front injector!!!!!!!
10-09-2008, 06:24 PM #18
yeah most likely there is an open in the #2 injector wireing or in the wires to that particular injecector. also could be that it became unplugged
10-09-2008, 08:07 PM #19
- Dec 2007
So, injector #2 causes cylinder number 8 to misfire?
10-11-2008, 04:26 AM #20
o shit lol no. i didnt even bother to check your OP. i was going Justin93 said, i losing it lol. you're right cylinder 8 if it was a p0308
security light flashing
By bbradberry in forum General HelpReplies: 6Last Post: 04-07-2011, 04:09 PM -
SES Light Flashing???
By SunsetZ in forum General HelpReplies: 19Last Post: 05-11-2009, 09:26 PM -
SES light, flashing?
By 666ws6 in forum General HelpReplies: 22Last Post: 08-11-2008, 05:03 PM -
No flashing light on the H/U
By Danger731 in forum Stereo and ElectronicsReplies: 1Last Post: 05-04-2008, 05:35 AM -
Please help!! SES light flashing!
By BITCHIN96Z in forum LT1Replies: 2Last Post: 03-02-2006, 09:15 AM
