04-30-2009, 07:03 AM #1
- May 2008
- New Brunswick
Alignment Spec handling/tire wear
I've searched through the threads here endlessly and I see a lot of variations on alignment set ups. (there are even 2 or 3 different suggestions as to what "factory specs are....for a 98-02 Trans Am)
Most of the "modified" set ups I see mentioned are being used by autoX/road racers with modified suspension so I don't know how those would apply to a car without lowering springs etc.
Personally I'm wondering what a good set up for basically stock WS6 would be. I have sway bars and SFC, but I don't think those make a difference in the alignment set up. But I was wondering if running 315s in the rear would affect anything.
I'm shooting for a more aggressive set up than stock but without causing too much extra tire wear....can anyone suggest how far from spec I might be able to get before wear starts to become an issue?
04-30-2009, 07:19 AM #2
- Oct 2007
- Beaver Dam KY
Very ironic because I got my tires balanced yesterday and a local shop testing out their service..(used a torque wrench.. everything was on he money, guy wiped his feet off and everything was nice)
Talked to them about getting my front suspension work done.. Got tubular UMI upper and lower( adjustable lowers only) a-arms and I need the specs on a good DD(yeah i know the rod end issue... oh well) that can perform as a good cruiser and performance as a good corner car and a good track car...
Subscribed...
05-04-2009, 03:53 AM #3
the common spec for overall a little better handling without increasing tire wear is this:
camber -0.50* left and right
caster +4.50* left +4.80* right
toe +0.03* left and rightCold Air Intake, Muffler Delete, Vinci High Performance Dual Valve Springs, Hardened Pushrods, Yella Terra 1.85 Rockers, Some Hydropdipped Stuff, Strut Tower Brace, Some SS Badges, boost/vacuum gauge, fuel pressure gauge, some checkered stripes, drilled/slotted rotors, ZL1addons Stealth wickerbill, Ruxifey LED side markers
05-04-2009, 06:01 PM #4
- Dec 2005
- Cincinnati
Black- 2001 Pontiac WS6 427ci
2001 WS6 LS2 427ci Forged Callie Crank, Billet Steel Compstar Connecting Rods, Forged Aluminum Wiseco Ceramic Coated Pistons, Stage III Ported & Polished Racing LS1 Cylinder Heads, F.A.S.T. 90/90, TTS LT's, GMMG exhaust, Spec stage III clutch, 18/19 iForged Aero's, Koni 4/4 Strano Springs.
05-04-2009, 06:22 PM #5
doesn't matter the ride height.
Question: Alignment Spec
By andyramsaran in forum GTOReplies: 3Last Post: 05-28-2010, 09:39 AM -
Spec ST2 wear time to short
By camarosspr in forum Manual TransmissionReplies: 0Last Post: 10-15-2007, 08:37 PM -
tire wear
By cobra12345 in forum General HelpReplies: 5Last Post: 08-12-2007, 02:57 PM -
Uneven tire wear on rear tire??
By renzo in forum Wheels and TiresReplies: 2Last Post: 11-20-2006, 04:30 PM -
Tire Wear
By SailorZ28 in forum Wheels and TiresReplies: 12Last Post: 03-22-2006, 05:33 PM
