Thread: simple yes or no...
07-04-2007, 08:54 PM #1
simple yes or no...
nothing crazy is required to change to a 160 t-stat is there??? such as pcm mods or anything?? just double checking before i install and make problems...
also could someone direct me to the do-it-yourself install section?? i saw before a thread on building your own bellows and i'm interested in the tb bypass... i would appreciate it if someone could point me in the right direction...
thanks guys!!!!
07-04-2007, 09:23 PM #2
- Jul 2006
- Westminster/Sykesville, Maryland
Red- 2000 Trans Am
its a easy swap. and you dont have to do anything else. but if you dont have your fan settings changed or put in a Switch for your fans you wont gain anything from putting a 160 in.
also if you buy one make sure you buy one for a 98-02 ls1. Jegs sold me a 160 for a 04+ ls1 and i had to make it work, dremel saved my ass 04+ thermo in a stock thermo housing
07-05-2007, 03:39 AM #3
go to www.installuniversity.com/ click ls1 installs, and then on the left side click install documents. full walkthrough. and probably a good site to bookmark.
07-05-2007, 07:00 AM #4
I've read that the Throttle body bypass is a complete waste of time. A cold air mod will give more benefit.
Not sure what other opinions are on this though.
07-05-2007, 07:18 AM #5
07-05-2007, 09:29 AM #6
- Jun 2007
- Dalzell, Illinois
red with black stripes- 2002 Trans Am WS6
i would suggest getting just the thermostat. i got one from jegs in the housing that didn't fit and one from orielly's that was the same. i went back to jegs and just got the replacement thermostat to fit in the stock housing.
07-05-2007, 11:44 AM #7
07-07-2007, 09:05 AM #8
thanks guys.... i'll be back for more of your knowledge!!!
07-07-2007, 11:05 AM #9
- May 2007
- Fredericksburg, VA
Black- 2001 T/A M6
Nope
A simple map
By GTP231 in forum Almost Anything GoesReplies: 54Last Post: 12-10-2011, 04:08 PM -
Simple Mods
By JBZ28 in forum External EngineReplies: 7Last Post: 10-18-2010, 06:42 PM -
Is it this simple???
By RealLiveMD in forum Internal EngineReplies: 4Last Post: 04-28-2008, 06:48 PM -
Keep it simple...
By 1EvilWS6 in forum NitrousReplies: 13Last Post: 11-23-2007, 03:58 PM -
a simple question
By zex Z in forum Camaro / SSReplies: 1Last Post: 07-24-2007, 08:52 PM
