Results 1 to 3 of 3
Thread: Clutch Problem
    TECH Fanatic AFASTYZFR1's Avatar
    USA
    Sunset Orange
    2001 Procharged Camaro SS
    Clutch Problem
    Just bled my clutch because fluid was really low and black......Now clutch pedal feels alot better but car drives like sh*t.....i get on it hard shift 2 second keep goin hard and the when i try and bang 3rd car wont go into gear like the clutch isnt engaged but doesnt grind.....car has 45xxx miles and is a 2001 Z28......any ideas
    Senior Member JonB's Avatar
    Florida
    2005 GTO
    Quote Originally Posted by AFASTYZFR1 View Post
    Bleed it some more there's probably air in the system.
    Member SSpdDmon's Avatar
    Farmington, MI
    SOM
    '01 Camaro SS
    Yeah, make sure all of the air is out of the system and there's pleanty of clean fluid in the resivior. You might need to have the slave cylinder replaced. You should also look into the drill mod for the master cylinder.
  1. another clutch problem
    By ali pontiac in forum Manual Transmission
    Last Post: 09-29-2010, 02:43 AM
  2. LS7 clutch problem.....
    By nmssr08 in forum Manual Transmission
    Last Post: 12-16-2008, 04:57 AM
  3. Clutch Problem
    By Blackout01 in forum Manual Transmission
    Last Post: 08-07-2007, 02:48 PM
  4. is it a clutch problem, or a tranny problem?
    By sgt0704 in forum Manual Transmission
    Last Post: 01-07-2007, 04:03 PM
  5. Clutch problem..help please
    By Scorch in forum Manual Transmission
    Last Post: 03-02-2006, 09:34 AM
