Thread: Oil too thick??
01-06-2006, 08:26 PM #1Sinister ZGuest
Oil too thick??
I live in Az and to help with a little oil leak and a slight rocker rattle, I bought castrol High Mileage 20w50 oil. I normally use Mobil 1 5w30 but heard in this hot climate I can use thicker oil and will be ok. Any thoughts or recommedations please? Thanks.
01-07-2006, 12:58 AM #2
If you've been running synthetic, stay with synthetic. Why would you want to be using a thicker oil anyway? As long as your oil pressure is ok, then use the lightest oil you can. If your oil pressure is so low that you need to start using a thicker oil, then you need to be thinking about a rebuild anyway.
01-07-2006, 08:28 AM #3
In a hot climate stick with 10W30, I also agree with 5.0THIS's post
01-09-2006, 07:52 PM #41BADLT1Guest
10-W40 at the highest but there isnt any reason to change unless you have hella miles on your car.
01-10-2006, 11:42 PM #5Sinister ZGuest
Car just turned over 103k. It doesnt smoke or burn a drop of oil though. Its a slight leak I havent been able to track down and fix due to have only one car. I went with Castrol High Mileage 10w40.
01-11-2006, 01:46 AM #6
So you went from synthetic to non-synthetic?
01-11-2006, 11:56 AM #7Sinister ZGuest
Yeah. I went through one cycle with the Mobil 1 in it.
01-12-2006, 08:04 PM #81BADLT1Guest
Originally Posted by Sinister Z
Do you find plus size/thick/big girls attractive?
By Murder after Midnight in forum Almost Anything GoesReplies: 24Last Post: 12-23-2014, 08:55 AM -
Are any of you guys attracted to thick women?
By Murder after Midnight in forum Almost Anything GoesReplies: 384Last Post: 11-26-2008, 11:45 AM -
CNC billet aluminum wheel spacers 5/16 thick $40
By BlownC5 in forum Parts For Sale / TradeReplies: 6Last Post: 04-21-2008, 03:11 PM -
Change Carrier or Use "thick" gears
By HasselZ28 in forum DrivetrainReplies: 2Last Post: 08-19-2007, 06:25 PM -
How to recognize a "thick" ring?
By tici in forum DrivetrainReplies: 0Last Post: 12-06-2005, 12:22 AM
