Thread: Power steering problem
05-11-2017, 03:13 PM #1
- Jun 2012
- florida
A few months ago I noticed a leak at the side hose that goes to the cooler a while back and I bought a new hose and clamps. Power steering was making noise so I took the filler cap off and there was a ton of pressure. Thats why its blowing off the side hose. What is causing this?
2002 ss camaro
05-12-2017, 05:55 AM #2
Check the fluid to see if it is "milky". The coolers can leak and bleed engine coolant into the P/S system -- bad. I removed our stock cooler and am running a small dedicated cooler mounted on the K-member.
05-12-2017, 03:05 PM #3
- Jun 2012
- florida
Fluid is empty, nothing to check.
05-14-2017, 05:32 AM #4
I am trying to remember if the cap is vented to compensate for pressure buildup when the fluid heats up.
05-14-2017, 01:03 PM #5
- Jun 2012
- florida
I was looking for that info also, could not find it.
Question: Power Steering problem.
By MrScary870 in forum External EngineReplies: 1Last Post: 07-08-2009, 02:11 PM -
By kappasig53 in forum General HelpReplies: 2Last Post: 04-01-2009, 05:43 AM -
power steering problem???
By camarostripes96 in forum General HelpReplies: 3Last Post: 06-04-2007, 10:44 AM -
By thundermax in forum LT1Replies: 4Last Post: 05-24-2007, 03:11 PM -
By TRU510 in forum General HelpReplies: 4Last Post: 04-28-2006, 03:04 AM
