Results 1 to 3 of 3
04-24-2008, 08:44 PM #1
Pulling rods and rockers without motor removal
Might be a topic on this somewhere, but have not found it. Is it possible to remove valve covers,rods and rockers without pulling the motor? Not much room under there. I would like to check my push rods and check rockers.
04-24-2008, 08:54 PM #2
- Nov 2006
- Broken Arrow, OK
There is no need to pull the motor to access the pushrods and rockers.
You shouldn't have any difficulty removing the valve covers, rockers and pushrods with the motor still in the car.
04-25-2008, 05:31 AM #3
+1 it's actually really easy! I like to put my #1 piston at TDC too, just in case shit goes wrong you can start from scratch. Those rocker bolts are torqued down to like 22 ft. lbs. so get a piece of pipe when trying to loosen them. Or you could just smash our hands on the wiper cowl when they break loose!
Best lifter,push rods and rockers
By rocketws6 in forum Internal EngineReplies: 9Last Post: 07-05-2011, 08:34 AM -
Pulling the motor again
By badazta in forum General HelpReplies: 0Last Post: 06-14-2008, 03:52 PM -
Need help pulling motor - broke motor at a road course event
By Doc99SS in forum General HelpReplies: 20Last Post: 08-24-2007, 05:57 PM -
Pulling out my motor Help!!!
By JD_Z28 in forum General HelpReplies: 2Last Post: 03-04-2006, 04:38 PM -
YUP, pulling the motor AGAIN!!!
By HASTINGSRJ in forum Western MembersReplies: 31Last Post: 10-27-2005, 06:19 PM
