Results 1 to 16 of 16
01-28-2011, 10:19 AM #1
- Aug 2010
- Oklahoma City, Oklahoma
sebring silver- Y2K SS CAMARO
BG headlight restoration kit with pics
I did the BG headlight restoration on my car last weekend and i thought i would share the results and guide you through the steps with a little more detail then the instructions give you.
The kit Part number is CA875 and runs around $55.00
First the supplies that are included:
two small sheets of 400 grit sand paper
one sheet of 1000 grit
one sheet of 2000 grit
foam brush
cleaning towel
two latex gloves
#1 prep solution
#2 cleaning solution
#3 sealant
these supplies are pretty good to get the job done but i reccommend getting these few things to go along with the included items.
three microfiber towels for each solution (they work better for cleaning the lens)
a five pack of each grit sand paper (the pieces included are small and hard to work with)
here is a pic of what the kit looks like:
Step 1:
apply a healthy amount of #1 prep and start out with the 400 grit sand paper make sure to go over the entire lens throughly. Dont be afraid to be a little rough to get the dis coloration and cloudiness out of the lens. Once finished throughly wipe with a microfiber towel (note: the lens will be VERY hazy after this but should be clear if there is still a yellow tint you still have more sanding to do)
Step 2:
Apply a good amount of #2 Cleaner to a NEW microfiber towel and wipe the lens throughly and press somewhat hard inorder to get all of the old plastic shavings out. Once clean let air dry for about 10 minutes.
Step 3:
re-apply more of #1 prep solution and use 1000 grit sand paper in the same fashion as step number 1 with a little lighter sanding. once finished repeat step number two with a NEW microfiber towel. the lens should still cloudy but a little more clear then the 400 grit sanding.
Step 4:
Once again re-apply the rest of prep #1 solution and use the 2000 grit sand paper. Now this is where being anal and particular comes in handy. (this is the step that took the longest for me). go over the lens completely as to remove all scratches. Once satisfyed use the last microfiber towel to clean while using the #2 cleaner. Allow to air dry for about 30 minutes or so. (or cheat and wipe it off with one of the clean towels that are provided in the kit)
Step 5:
Once the lenses are COMPLETELY dry apply a large amount of bottle #3 sealerto the foam brush. move from the top on the light to the bottom in even and smooth streaks as to prevent bubbles or streaks. (REMEMBER you can put too much on and end up having a run the the product). keep smoothing the product out to get rid of any lines or imperfestions that may still exist. Allow to dry for a few hours. (the kit says only 30 minutes or so but mine took on the upwards of 2 hours to fully dry).
After this you will have new looking headlights. Enjoy!!!
before this is what the looked like:
and this is what they look like now:
and a few with the HID's
01-28-2011, 10:40 AM #2
That came out good.
2002 Artic White SS 35th Wheels|Full Hotchkis Suspension|Koni SA|Magnaflow CME|SLP lid|www.fquick.com/The_Guz
01-28-2011, 12:24 PM #3
01-28-2011, 09:13 PM #4
- Thornton, CO
Congrats on the improvement.
Although it could have been done for a bit less coin.
I did a hell of a job on the Grand Am's headlight lenses for the cost of 1500 and 2000 grit sandpaper. Of course, I already had the portercable to clean them up after that....
01-29-2011, 06:07 AM #5
01-30-2011, 04:06 PM #6
01-30-2011, 10:10 PM #7
Nice write up. Thanks for posting...
Out of that kit, I think the 400 grit sandpaper is an overkill.
01-31-2011, 04:59 AM #8
02-06-2011, 07:57 PM #9
- Nov 2009
- NOVA
2002 C5 - M6 - Blue- 2000 Z28 - A4 - Pewter
Depends on how bad your lesnses are, to decide if 400 is overkill. Mine were absolutely horrible. I went, 400, 600, 800, rubbing compound, cleaner wax, polishing wax on both of my Zs. Got pictures of the white Z before and after... used 3m paper, turtle wax compound, and meguiars for my waxes... here's mine. I did a write up not long ago on mine as well. I think it cost me around $30 total for everything.
Before...
After...
02-24-2011, 03:59 AM #10
- Jun 2009
- Northern Ohio
Pewter- 2002 Trans Am Convertible
ive only ever had a few cars that were soooo bad i had to use sandpaper on it. and i didnt have to use worse than 1000 grit.
Below is my 2000 Grand Am GT that i had to use sandpaper on. It was so thick it was crazy. Ive done well over 100 headlight restorations. Meguiars 105 on a yellow pad does more that you think. If you buy an aggressive enough polish, like 105, it will save lots of sanding.
I used 1000 and 2000 wet, and M105 on the Grand Am GT.
This late 90's Toyota Tacoma has 300,000 miles on it and the headlights have never been touched. This is the shop truck at the motorcycle shop i work at. All i used was M105 and a yellow pad. NOTHING else.
you can see how the 105 works here!
98 Mustang with 120K. These were really bad too. Used 1000 &2000 wet and M105.
13 year old Silverado with 200K lamps... 1000 & 2000 wet and 105.
Its crazy how many people will pay 30 bucks for me to spend 20 minutes on there headlights! its cheaper than 100 + bucks for new headlights housings.Last edited by 02convertibleT/A; 02-24-2011 at 04:16 AM.
02-24-2011, 07:22 AM #11
02-24-2011, 09:39 AM #12
02-24-2011, 09:50 AM #13
- Mar 2007
- Henryetta/Tulsa Oklahoma
Looks good Wicked. I did mine with 400, 800, 1200 and 2000 grit, and Meguiers PlastX. I made the mistake, though, of not using a sealant...and it shows. It'll be time for round 2 soon, shouldn't have to use below 1000 grit this time, and just make sure I seal it up.
02-24-2011, 10:07 AM #14
02-24-2011, 10:33 AM #15
02-24-2011, 10:34 AM #16
Headlight Restoration... THE RIGHT WAY!!!!! Pics!
By rappin_ernie in forum Camaro / SSReplies: 55Last Post: 10-10-2011, 04:38 PM -
By rappin_ernie in forum Appearance SectionReplies: 14Last Post: 06-20-2010, 07:48 PM -
Headlight restoration (pics)
By GoFast908Z in forum Showcar and DetailingReplies: 6Last Post: 04-05-2010, 06:00 PM -
By LS1Jason in forum Showcar and DetailingReplies: 12Last Post: 04-14-2009, 03:53 PM -
Headlight Restoration Kit
By LETHALxLS1 in forum Showcar and DetailingReplies: 19Last Post: 08-17-2007, 09:15 PM
