Results 1 to 10 of 10
    We'll be back... GatorSS's Avatar
    THE SWAMP
    Light Pewter Metallic
    2000 Camaro SS M6
    Creaking front end
    I haven't messed with my SS in awhile, but pulled it out for the campus parade with our new basketball National Champions and I hear this creaking sound from the front as soon as I back out from the garage. Driving around it made some more creaks and squeaks. Just pushing down on the front of the car re-creates the noise.
    So, I figured I'd pull out the grease gun and lube it, but I didn't see any grease fittings upon sticking my head under the front. Are there any? Hmmm... I suspect it may be coming from the sway bar bushings, but I don't know right now. Since I didn't have the time to lift the car and really spend some time checking it all out, I thought I'd post and get some feedback from y'all.
    When this semester is over and after I return from a vacation in the Bahamas, I'm planning to spend some time doing some upgrades to this toy. But until then, can you guys give this ole professor some help? I know I can't be the only one that has dealt with this...or could this be a trick that some George Mason fans are playing on me because my students sent Cinderella home early?
    Senior Member splitfinger09's Avatar
    Bartlesville, Oklahoma, United
    Bright Rally Red
    2000 Camaro SS #5075 M6
    So are there any grease fittings on the camaro? Any place to hook up a grease gun? Thanks
    That guy thearborbarber's Avatar
    SoDak
    White over Red
    1991 Suburban
    I have had the sway bar bushing make the same noise you describe on a ford I used to drive. When ever it got cold and the rubber got hard it would creak and squek.
    Chris
    What the Hell! SuperSport's Avatar
    Orlando, FL
    Experienced this on my 02 rear sway bar bushings. They need to be greased.
    Brian
    '02 Camaro SS Convertible: The Garage...
    September, 2007 COTM
    I have a need for speed! jigger1166's Avatar
    Standish,Maine
    Artic White
    00 SS Vert.
    It sounds like the Ball-joints are dry. I can't remember if they're greasable, but if they are, greasing them should take care of it. If they're not greasable, you'll have to replace the noisey one.
    JIGGER RACIN'
    2000 Camaro SS, vert., auto., LS6 intake manifold, SLP lid, K&N filter, SLP LoudMouth II, C5 Z06 replica 17x9.5 rims
    1/4 mile time = 13.310 sec. @ 105.22 mph, 2.051 60'
    http://www.cardomain.com/ride/2939958
    http://i158.photobucket.com/albums/t...amarolaeft.jpg
    d
    2002 z28
    does that also but went away HMMMM
    02.LS1 Anniversary Issue
    sacramento
    dark purple/chameleon
    anniversary 02 camaro LS1
    sounds to me that it could be one of two things.......either the bushings are wore and bad from over the time weather abuse or road conditions or the ball joints need to be greased. .....and i dont think that the front end of the camaro's have grease fittings but i can be wrong. although i have been under mine alot and enough to know that i havent seen any:_)
    My Neighbors Hate Me!!! lvbroham1's Avatar
    Jun 2006
    Ft. Lee, Virginia
    Artic White
    2001 Chevy Camaro SS
    Had this same problem with my 2000, ended up being the front shocks going bad. It would probably be a good idea to get a mechanics stethoscope and have a buddy push on the front of the car while you listen so you can pin point it. Just my 2 cents.
    LS1 Noob
    Fredericksburg, VA
    2000 WS6
    I have a very obnoxious creaking noise coming out of my front passenger side area. It seems to be the shock. It only happens when the temperature outside is hot (90 degrees or more) and is more noticeable in slow stop and go traffic. I'm still trying to figure out why it only happens when it's hot?! Crazy ass thing...
    Member 02WS6dream's Avatar
    Jun 2006
    Charlotte, NC
    08 Mustang GT/CS Blue
    2002 Trans Am WS6 traded
    I have creaks and squeaks; mostly from the rear, that get very noticeable when it gets cold. I have been told at the dealer and read on here that its common. i can't recreate it just by pushing on the car, but it does it over speed bumps. I was told thay the bushings looked good and haven't really worried about it. Let us know what you find out!
  1. Loud creaking
    By ccislander in forum Suspension and Handling
    Last Post: 06-22-2011, 04:46 PM
  2. Creaking when turning below 5MPH
    By ss~zoso~ss in forum Camaro / SS
    Last Post: 04-21-2006, 11:08 PM
  3. Creaking rear end
    By Sonic in forum Drivetrain
    Last Post: 04-20-2006, 02:17 PM
  4. creaking sway bars?
    By masterblaster in forum Suspension and Handling
    Last Post: 01-09-2006, 06:36 PM
  5. squeking and creaking
    By 01WS6_4_ME in forum Camaro / SS
    Last Post: 11-04-2005, 11:40 AM
