Results 1 to 3 of 3
Thread: MM6 Ratios
06-18-2013, 06:42 AM #1
- Jun 2012
- florida
MM6 Ratios
Are the Tremec gear ratios the same for different cars, ie transam and gto with 6-speeds.
06-18-2013, 08:55 AM #2
- Apr 2010
- Alabama
I don't know specifically for trans am vs gto but I know non-gm brand tremec 6 speeds have different ratios. I want to say the gto and TA ratios are close but I am not 100% positive and I could be totally wrong.
1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
06-18-2013, 09:44 AM #3
- Jun 2012
- florida
radios
I found the info on the net, the ratios are the same between ws6 and gto and the rear end ratios are the same. I have both cars, same diameter tires yet they drive differently. I can get the gto into 6th around town at 2000rpm. The transam I have to be on the freeway before I can shift into 6th. Also the factory specs are different with the same driveline setup. gto=13.8 @ 116 and transam 13.0@108. Gto has a faster top speed but its slower in the et's. Why is this?
weight to hp ratios
By FutureWS6 in forum Firebird / WS6Replies: 8Last Post: 04-12-2010, 10:37 AM -
Compression ratios
By 98redconv in forum Internal EngineReplies: 22Last Post: 12-08-2008, 12:34 PM -
gear ratios
By ls1colorado in forum DrivetrainReplies: 5Last Post: 07-08-2006, 11:26 PM -
Gear Ratios?
By senior gomez in forum DrivetrainReplies: 2Last Post: 12-07-2005, 05:10 PM
