Thread: What all do i need?
12-30-2007, 11:09 AM #1
What all do i need?
sorry if its on the site already i searched n couldn't find it...but i plan on doing tsp TD's and Pacesetter LT's and what all will i need (example: o2 extensions,gaskets,header bolts..?)and wheres the best place to buy?also has anyone tried speed inc TD setup for 230 bucks?
12-30-2007, 04:19 PM #2
- Nov 2006
- Broken Arrow, OK
I remember you had a thread similar to this a few days back, but can't recall if you got long tubes with or without the AIR and EGR provisions. You will want 2 12" 02 extensions, its not a bad idea to new GM header gaskets, and I recommend getting some Stage 8 locking header bolts. You won't want to use the ones that come with Pacesetter. You want to put antiseize on the header bolts as well.
Its also a great idea to put new plugs in and possibly new wires while you are doing the header swap. One of the best tips I can give you for the install is to pull the coil packs off, it gives you a lot more room to work with and pull the starter to get the passenger header in.
01-01-2008, 12:47 PM #3
alright thanks and where can i get antiseize and the header bolts
01-01-2008, 06:16 PM #4
