Results 1 to 3 of 3
06-26-2011, 11:41 PM #1
- Apr 2011
- WV
Black- 2000 T/A LS1 M6
which lsx heads are compatible with my ls1
ok so i am wanting to eventually upgrade my stock ls1 241 heads to something better to go with my cam, lt header, ory pipe install this winter. i do not want to go drop thousands on a set of heads. i have been looking on parts classifieds on forums but to be honest, i have no idea what numbers i should be looking for.
so which heads off other ls motors are compatible with my 2000 ls1. i'd like to avoid upgrading my intake but that is not out of the question. there is just too many options for a newbielike are ls2 or ls3 heads compatible? what about these 243 numbered heads and what not. i did read the sticky on here about all that but i am still lost
thanks guys
06-27-2011, 06:15 AM #2
- Dec 2005
- Laurel, Maryland
Any heads with Cathedral Intake Ports, as seen below:
243 Heads flow better than stock LS1 heads (853 or 241). I ran ported 5.3L heads off of a LM7 (truck motor). They outflowed ported 243 heads, but I think that's because I pushed the limit with the porting and went beyond the normal on the CNC machine. Also, stock 5.3L heads have a smaller combustion chamber, so you can bump the compression higher than stock. I had mine milled, so my compression was over 11:1.
06-28-2011, 12:24 PM #3
- Apr 2011
- WV
thanks for the info. i have done some research. i think i am going to go with a good, used set of ls6 heads
Question: Is LT1 intake LS1 compatible?
By MarcusJ in forum External EngineReplies: 14Last Post: 10-15-2009, 10:20 AM -
are these parts compatible?
By NetrixTardis in forum External EngineReplies: 1Last Post: 08-11-2007, 07:54 PM -
LS1 compatible parts with LS2?
By Johns00Z28 in forum General HelpReplies: 20Last Post: 06-24-2007, 06:59 PM -
Its RXP compatible with Seafoam?
By CandyRedZ28 in forum General HelpReplies: 0Last Post: 06-14-2007, 01:52 PM -
ls1 Center Console compatible with lt1
By PurePwrTA in forum General HelpReplies: 0Last Post: 09-06-2005, 09:24 PM
