Results 1 to 20 of 86
Thread: Hole in block...
10-03-2008, 10:38 AM #1
Hole in block...
That's right, I go to start up my car this morning and it's idling low and sounded like it was missing, so I got out to check and all of a sudden I heard this horrible chattering noise so I shut it off immediately. I looked underneath and saw a chunk of aluminum (a little bit bigger than a quarter) laying on the ground!!! I get underneath and my worst fear was confirmed; I have a hole in the block right behind the motor mount on the passenger side.
I just took pics, but my batteries in my camera took a dump,so I have to wait until they re-charge to post them.
I've got 1,000,000 things swirling through my head right now, but Id like to hear some other people' thoughts on what to do in terms of a rebuild...? Car has 85,xxx on the clock, so I'm thinking maybe have the rotating assembly specced and see if it's worth re-using and re-furbing, and just buying a new/used block and slappin it back together. Another idea would be to buy an lq4/lq9 motor and swap it in, with the intent of going bigger cubes in the future... (can't really afford the heads, cam, intake, drivetrain upgrades, etc, etc, right now) As of right now my budget is only about $1500, but now I have all winter to save up and put money aside...Thoughts would be greatly appreciated!!!
10-03-2008, 10:44 AM #2
- Thornton, CO
Hole in block = more than a rebuild.
There is a freeze plug in that area. Is it that by chance?
10-03-2008, 10:47 AM #3
10-03-2008, 10:49 AM #4
- Thornton, CO
So the block is dead.
Gonna be hard to determine what you have to replace and what (if anything) will be re-useable.
When it pukes like that, it is normally everything.
Maybe a used LQx for now...
Probably won't find an LS1 replacement on that tight of a budget.
10-03-2008, 10:55 AM #5
Yea figured that...I know Hi-po is putting down some pretty impressive #'s with his LQ4 motor before the FAST 92/92, and with the stock truck cam...Maybe that is the way to go for now, then punch her out later.
I'm pretty sure some shit fell into the motor too, cause it was chattering like HELL for about 5 seconds until I could shut it off...
Is the aluminum block worth anything...?
10-03-2008, 10:57 AM #6
- Thornton, CO
Not with a hole in it.
10-03-2008, 10:59 AM #7
10-03-2008, 11:00 AM #8
10-03-2008, 11:05 AM #9
No clue really...? I drive it once or twice a week, usually pretty easy on it...Oil changed frequently enough (PP 10w-30 insummer, 5w30 in winter and it's changed every 5,000 miles)
My motor mounts are WEAK AS SHIT and when I was under the car last week getting my exhaust work done th guy said I should get new mounts. I was going to order them next friday...When I was under there this morning I noticed cracks in the block right in the area of the mounts...and obviously, the hole!
10-03-2008, 11:06 AM #10
10-03-2008, 11:08 AM #11
- Thornton, CO
Interested to see pictures once you get inside of that motor.
Good luck!
Feel free to PM me if you need help (if you plan on doing the swap).
10-03-2008, 11:11 AM #12
I'll keep it updated, thanks!
Do you know of any good guide for the LQX swap? I'm probably gonna pull the motor out the bottom, but I don't have a lift (or a garage yet, because my landlords daughter still has shit in it), so I was thinking maybe some tall ass jack stands (they use them for off roading), or lifting the body up from the shock towers?
10-03-2008, 11:13 AM #13
- Thornton, CO
That is how I did it.
Put the rear on ramps, use a STB to lift the car using a hoist.
10-03-2008, 11:21 AM #14
- Sep 2007
- Philly+Glenmoore, Pa
The worst dude! what a bummer. Hope you can get it up and running soon. You could maybe store up in my garage. we'll talk about it.
10-03-2008, 11:21 AM #15
10-03-2008, 11:24 AM #16
Yea, it sucks! I didn't wanna replace the motor until the car was paid off haha but such is life...
Thanks for the offer on the garage space, I'll have to see what's up with my landlord and if she can get some shit out ASAP haha... I wanna get the motor outta the car soon though...
10-03-2008, 11:24 AM #17
10-03-2008, 11:24 AM #18
I have a stock block, 22k miles on it...forged rod bolts...heading up the east coast on the 16th of Oct....
http://www.ls1.com/forums/showthread.php?t=97039
10-03-2008, 11:27 AM #19
- Sep 2007
10-03-2008, 11:30 AM #20
I'm an A$$hole
By weberje in forum Firebird / WS6Replies: 34Last Post: 03-29-2010, 04:50 PM -
Chevy Small-Block, Big-Block & Transmission Buildi
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 11-20-2009, 01:50 PM -
Which hole?
By pajeff02 in forum Suspension and HandlingReplies: 13Last Post: 10-15-2009, 11:37 PM -
WOW! what an A-HOLE!
By Smittro in forum Almost Anything GoesReplies: 12Last Post: 09-26-2009, 11:36 AM -
Hole-in-One
By BadBlueBird* in forum Almost Anything GoesReplies: 24Last Post: 10-23-2006, 08:09 PM
