Results 1 to 3 of 3
Thread: Will LS1 catbacks fit LT1's?
07-29-2006, 09:47 PM #1
- Mar 2006
Just as the title says... Any changes made to the body that would affect the mounting on a LS1 exhaust system to a LT1?
08-04-2006, 10:42 AM #2
I think the mufflers are the same and the hangers but the only diff is the y pipe and such, but from the i pipe back im thinkin there the same
If im wrong someone correct me.
08-04-2006, 11:08 AM #3
from the i-pipe back, they are the same. you will need to find a way to hook to it with your y-pipe. the LS1 y-pipe meets at the driveshaft tunnel. the LT1 both meet on the driver's side. then one pipe from there over to the driveshaft tunnel.
Catbacks? which one?
By Edward-T in forum General HelpReplies: 7Last Post: 08-30-2011, 08:57 AM -
Anyone ever try these catbacks?
By JoshuaGrooms83 in forum External EngineReplies: 5Last Post: 01-10-2011, 06:47 AM -
Are true duals better than catbacks?
By KnightmareWS6 in forum External EngineReplies: 40Last Post: 04-23-2010, 06:20 PM -
Help: Intakes, headers and catbacks????
By firebird400 in forum GTOReplies: 16Last Post: 04-17-2009, 08:00 PM -
Cherrybomb Catbacks?????
By Heartbreak1 in forum External EngineReplies: 5Last Post: 06-26-2007, 09:51 AM
