Thread: 350 turbo trans swap
07-03-2011, 07:38 PM #1
i have a 1995 camaro with a 4l60e trans and i am thinking of putting a 350 turbo trans in the car. i was wondering what all i would have to do to make it work. thanks
07-03-2011, 07:39 PM #2
the car is a z28 with a lt1
07-03-2011, 07:44 PM #3
- Feb 2007
- San Diego, CA
1st question is: Why? TH350 has a 2.52 1st gear vs 4L60 having a 3.06. TH350 = no OD gear.
While it can be done unless this is a dedicated race car the swap just doesn't make sense.67 Camaro: K-K + 797-z (look it up), 454/Th400/4.10 12-bolt = 6mpg, PS/PDB/PW tilt, tach, gauges...
Carbon footprint? CLOWN SHOE!
07-03-2011, 07:51 PM #4
my 4l60e trans is shot and i happen to have a 350 turbo ready to go. this car is a weekend car. not a every day driver. i have a none lock up converter i plan on using with the trans. i am wondering if the trans mount and drive shaft will work
07-03-2011, 07:53 PM #5
i have been running the car with no first gear with the same style converter for a while and it still comes out the hole good
07-04-2011, 04:51 PM #6
Trany will bolt right up, drive shaft will have to be made or altered, (iirc) the TH350 is shorter than the 4L60e..
So there may be more needed than just an altered DS.
It's been ~30 years since a Camaro with the TH350 was built,
so you'll likely have to do something different with the trany cross member, and torque arm..
You can always change rear gears to overcome the 2.52 takeoff we're only talking roughly a little over half a turn or 0.54 difference..
07-24-2011, 05:42 PM #7
sending you a pm to a website to check out.
07-24-2011, 05:45 PM #8
hmm says i cant when i try...
Trans swap for swap
By [CJ] in forum DrivetrainReplies: 0Last Post: 08-12-2011, 12:11 PM -
Question: 4l60e swap to turbo 400
By camhead68 in forum Automatic TransmissionReplies: 14Last Post: 09-01-2010, 11:13 AM -
Wanted: STS turbo for trans am
By larryndog in forum Parts Wanted / TradeReplies: 2Last Post: 01-18-2009, 07:39 AM -
Question: M6 Trans swap
By kool-aide in forum General HelpReplies: 10Last Post: 02-23-2008, 06:27 PM -
Turbo for trans am
By Arrison24 in forum Forced InductionReplies: 21Last Post: 06-10-2007, 02:42 PM
