Thread: a couple problems
12-02-2008, 09:01 PM #1
a couple problems
so i have a few problems that have recently started with my bird.
1) whenever i roll down my drivers side window, it will stop halfway down. it does the same when trying to roll it back up. i have to wait a few minutes and try again and sometimes it only goes up about an inch or so. could it be my window motor going out or something else?
2) i know i need a new clutch but something else just started acting up that im curious about. whenever i shift into 4th gear, i would feel a grinding in the stick. i can double-clutch it going into 4th and it wont grind and it also doesnt do it when im downshifting from 5th. i noticed i cant get it into 4th at higher speeds. i had my car up around 90 mph or so and tried going into 4th but it kept grinding. occasionally it wont fully go in and then it will pop out of gear. however, once i do get it into 4th, then its fine. i was thinking maybe synchros but im not a mechanic so i have no idea
3) whenever i start my car, my fan turns on. my fan is always running when my motor is. could it be a stuck relay or something? it just gets annoying standing outside my car while its running and hearing my fan over my motor.
any input is much appreciated
12-02-2008, 10:23 PM #2
- Aug 2008
- Aurora, Illinois
White/Gold- 99 T/A sold/67 Firebird
#1 possible window switch
12-02-2008, 10:31 PM #3
#1 Will be your window motor most likely.. Easy to install, but you have to drill the factory rivots out. Not hard to do, the new motorwill come with bolts and locking nuts.
#2 Change the clutch/flywheel even if its a stock one from a Auto Parts store (they will actually hold a lot of power and come with a warranty). Change it ASAP along with your slave cylinder. You don't want to ruin your transmission. I waited too long to change my clutch, cost me 1500$ to get it rebuilt. But the clutch might not fix it. I could just be your shift fork in 4th is skewed or bent.
#3 Relay/Fuse
12-02-2008, 10:37 PM #4
- Nov 2006
- Alachua, Fl
Ignition Orange/Black- 2008 G8 GT, 98 Z28 383
#2 Is maybe your synchros. It also could be your hydraulics(along with the clutch). When you get your clutch replaced make sure they put in the Master and Slave cylinder from an 01-02 T-56. The ones from 98-00 were garbage. I suggest going to at least a Z06 Clutch as well in lieu of the stock one. I had the same problem with almost every one of my M6 cars. Has it started doing it from 1st to second? If you end up getting the synchronizers replaced you may as well have them rebuild your tranny while theyre in there... I had some other kind of shift forks put in mine besides the brass stock ones which get bent easy... I think it was steel I cant remember. Do your clutch ASAP. Fucking T-56. I spent a lot of money getting the one in my last car working right.Last edited by wooddaniel; 12-02-2008 at 10:39 PM.
12-03-2008, 07:48 AM #5
- Oct 2005
- Eastern, Kentucky
Black on Black- 2000 Trans Am M6
#1 is your power window motor, but Ive had no experience with your other two problems
SLP LT's, SLP High Flow Cats, 3" Flowmaster CB, Comp Cam, SLP Lid, LS6 Intake, BBK 80mm TB, SFC, Ram Air HO Hood, Lowered, Torq Thrust II's
Couple of Problems
By LgndKller20073 in forum General HelpReplies: 7Last Post: 08-09-2013, 10:43 AM -
ok so a couple of problems..
By Ws6islife in forum Firebird / WS6Replies: 1Last Post: 10-15-2009, 08:52 PM -
A couple ?s about RX8's
By 01ls1ws6 in forum Almost Anything GoesReplies: 11Last Post: 04-20-2009, 02:10 AM -
Couple of ? for you all.
By transam98 in forum Internal EngineReplies: 4Last Post: 11-28-2007, 05:24 PM -
couple Q's
By NxLS1496 in forum Camaro / SSReplies: 13Last Post: 12-10-2005, 01:50 PM
