Results 1 to 3 of 3
Thread: Jersey Jeff in the house!
07-29-2007, 01:26 PM #1
- Jul 2007
- springfield,nj
black- 98 ws6 firebird
Hi, I have 1998 WS6, 6 speed, 4.10 rear, cam and exhaust. I started to use it for road racing. It runs 180 around town and on the highway.
First day at the track it overheated all day as high as 260 degrees. I have a 160 thermostat. I don't know if I should install a fan switch or cooling ducts or bigger radiator. Thanks, Jeff
07-29-2007, 01:49 PM #2
07-29-2007, 01:58 PM #3
Def get the bigger radiator. You can tune the fans to come on at 160 if you haven't already. On Camaro's they have plastic shrouds on the bottom, I took those off to bring more air into the engine compartment, maybe you can do the same, you can also check out TA hoods w/ the heat extractors man. Hope that helps! Welcome!
