Results 1 to 3 of 3
Thread: How do I check my TPS
04-11-2011, 12:21 PM #1
- Oct 2008
- New Brunswick Canada
Black- BLK TA modded 12.2@113mph
I had a mail orderf tune done and now it shifts at 5700rpm instead of 59 or 6000rpm I was told by Frost to check my TPS before we play with rpm range How do I do that I need to know if it opens 100%????
Thanks
04-11-2011, 07:37 PM #2
- Apr 2008
- Madison, WI
back probe the dark blue wire.
Hook up volt meter: Red lead to the backprobe and Black lead to a good clean ground.
set up the meter so you can see it and read it while you are sitting in the car.
Hop in the car, turn the key on but engine off. DON'T START IT!
press the gas pedal to the floor and read the voltage.
The WOT voltage should be more then 4 volts but less then 4.75 volts
04-12-2011, 09:11 AM #3
Desks - check, phones - check, Cuban Flag with pic of Che - check
By dock in forum Political / Debate ForumReplies: 5Last Post: 02-13-2008, 06:30 AM -
Check It Out!
By OnEbAdReDSS in forum Camaro / SSReplies: 19Last Post: 01-27-2008, 01:53 PM -
check this out
By kyemt in forum GTOReplies: 6Last Post: 06-14-2007, 02:59 PM -
Check this out
By dkishton1486 in forum Parts For Sale / TradeReplies: 1Last Post: 04-20-2006, 04:00 PM
