Thread: fuel tank
11-05-2009, 12:37 PM #1
fuel tank
i need some info on fuel tank removal on a 2006 GTO. the fuel lines under the is where i'm stuck.
11-06-2009, 01:42 PM #2
- Jan 2009
- Chesapeake, VA
Carousel Red- 2005 Pontiac GTO
Not sure how you're making out with this, but when I did it I had to have my brother wiggling the tank out of the trunk while I was underneath making sure the lines went where they needed to go. Be VERY careful when unclipping the fuel line, it's a PITA and easy to break the clip part. I don't have much more info than that, hopefully it helps a little bit.
When putting it all back together you'll also need help so you don't pinch the fuel line while re-installing the fuel tank (threading the fuel line back down through the floor of the trunk).
S.
11-06-2009, 05:47 PM #3
f/tank
hey Scauffiel thanks buddy. I did call a friend to help with lifting the tank out and reinstalling it. I noticed that if lean the tank towards the the rear and down and sliding it at the same time one person could manage w/o damage to the lines. Why take a chance. Lifting it out is another thing. It is best to have four eyes on the job. The lines probably cost enough to hurt my poor ass.
11-06-2009, 05:53 PM #4
- Jan 2009
- Chesapeake, VA
Glad you got it worked out man; when I called about replacing those lines (because I broke the clip on the connector) I was told you couldn't replace them - they only came with/on the fuel tank.
S.
11-08-2009, 03:28 AM #5
- Mar 2008
- OHIO"S only 9 second GTO
Phantom Black Metalic- 2005 GTO
those lines are a pain, best to have a freind help,there are fittings out there you can make a new supply line,(Russel makes then as well as aeromotive)those are crap from the get go,I always replace them on my turbo setup as i go to the return style setups.
11-08-2009, 03:34 AM #6
11-09-2009, 04:05 AM #7
- Mar 2008
the Aeromotive part # 15118 its a -6an or 3/8 line will need 2 of these they will have a -6an female fitting on one end and the other pushes up on the bottom of the tank and the other will go to the fuel line(metal one from the car) feed line stock.I also know a place who sells these on ebay,by the pair of them cheaper then you can one of the Aeromotives.http://cgi.ebay.com/ebaymotors/Retro...cessories,this place has lots of neat shit for our cars and priced right!
11-09-2009, 04:33 AM #8
- Jan 2009
- Chesapeake, VA
Excellent - I'm going to check it out and probably spend far too much money. Is there going to be a difference between the 04's and 05-06's? Or does it matter back there at the tank? It's my natural inclination to guess "no" but this IS GM we're talking about.... lol
Help: 98 TA fuel smell coming out of the fuel tank neck/cap
By JayTA98 in forum General HelpReplies: 23Last Post: 04-09-2014, 09:35 AM -
possible to use a 99-02 Fuel pump in a 98 tank??
By mike171562 in forum External EngineReplies: 4Last Post: 02-01-2011, 11:42 AM -
Sugar in Fuel Tank!
By RedDemon2 in forum General HelpReplies: 24Last Post: 05-20-2007, 04:47 PM -
Sugar in Fuel Tank!
By RedDemon2 in forum Firebird / WS6Replies: 16Last Post: 05-02-2007, 08:38 AM -
Fuel Tank Leaking,,,
By ANUTT1 in forum General HelpReplies: 4Last Post: 01-04-2006, 08:13 AM
