Results 1 to 11 of 11
07-21-2007, 05:43 PM #1
Fuel filter replacement...how long?
How hard is it to replace the fuel filter? I don't even think I know where it is, and I sure as hell know it hasn't been replaced in the last 4 years!
07-21-2007, 07:42 PM #2
It shouldn't take more than 20 minutes. Located in front of the rear axle on the driver side.
Be prepared to have gas all over you.
07-21-2007, 11:16 PM #3
Chiltons manual. You need one
07-21-2007, 11:25 PM #4
07-23-2007, 12:22 PM #5
First off, Make sure and use line wrenches so you dont strip anything.
1.Get the car on a lift or jackstands
2.Open gas cap to relieve pressure
3.Use your 2 line wrenches to loosen the line
4.Use flathead for the 2 clips at the other end
4.Be prepared for a gas shower =/ (worst part)
5.Put new filter on and you are good to go =)
07-23-2007, 12:24 PM #6
The second time I did it, I bled the valve on the fuel rail first before taking of the filter. That seemed to reduce the amount of fuel that spills out.
07-23-2007, 12:31 PM #7
how often do you need to replace the fuel filter?
07-23-2007, 12:32 PM #8
I'm not really sure. I've done it about every six months.
07-23-2007, 01:28 PM #9
you can also start the car then pull the fuse for the fuel pump and you won't get alot of gas on you.
07-23-2007, 01:54 PM #10
07-24-2007, 05:46 AM #11
yea holy shit, i just completly forgot about it... i havent done it since i got the car in 2/2003!! ive only put about 20k on it since though so...
replacement filter for K&N FIPK
By werewolf in forum General HelpReplies: 10Last Post: 04-07-2011, 04:45 AM -
kinked fuel line while changing fuel filter
By krese in forum Firebird / WS6Replies: 4Last Post: 10-04-2010, 03:02 PM -
fuel filter replacement help
By L...S...1 in forum Camaro / SSReplies: 3Last Post: 12-21-2009, 01:39 PM -
Question: Does a new fuel pump mean a new fuel filter too?
By RaceMyLS1 in forum General HelpReplies: 3Last Post: 02-16-2009, 11:11 PM -
fuel filter or fuel pump?
By formulaon18s in forum General HelpReplies: 6Last Post: 11-20-2007, 04:14 PM
