03-18-2014, 03:41 PM #1
Forward vents don't work....help!
My forward air vents just stopped working. Only the defrost and floor vents work. Did some research and found that the vacuum tube has snapped off near the passenger side headlight. What the heck is this replacement tube called???? Can't find a pic or name on the internet. It's about 4 feet long and less than an 1/8" diameter tubing....
03-18-2014, 04:56 PM #2
- Oct 2008
- Coral Springs, Fl
On the passenger side shock tower in the engine bay right behind the hood lift shock mount there is a small vacuum check valve. My guess is it's cracked or no longer working properly.
New one is around $5 at the auto parts store
Looks similar this
03-18-2014, 05:19 PM #3
I found the splitter but the actual tubing has snapped in half, so I need a whole new 4 foot tube. I don't know what it's called and can't find it on internet search engines....
2001 Chevrolet Camaro Z28, M6, Eibach Pro-kit, BMR STB, BMR Adj-PHB, BMR RB's, BMR SB's, BMR Adj-TA, KYB Adj-shocks, K&N, SLP LM, SLP Y-Pipe, SLP Intake, Predator Custom Tuned...
Treat her well and she'll put a smile on your face every time you get on her!
03-18-2014, 05:25 PM #4
- Oct 2008
- Coral Springs, Fl
Silicone vacuum hose
03-18-2014, 05:26 PM #5
Have you tried your local auto parts store? They'll probably have tubing/hoses that will work.
03-18-2014, 05:33 PM #6
Just trying to figure out what to call it. I'll take a pic and bring it with me to the auto parts store...
03-19-2014, 07:56 AM #7
They might be clogged.
03-19-2014, 07:23 PM #8
- Jan 2009
- North Jersey
Like Alex posted, use the silicone vacuum hose and splice it onto the undamaged factory line.
HVAC VENTS and Plastic 3 way valve (defrost to vents)
By barberjd in forum Firebird / WS6Replies: 3Last Post: 08-27-2023, 05:17 PM -
Anyone else looking forward to Futurama?
By Mr. Luos in forum Almost Anything GoesReplies: 23Last Post: 06-27-2010, 10:21 PM -
Flash Forward
By DrMilhouse in forum Almost Anything GoesReplies: 4Last Post: 05-24-2010, 05:59 PM -
Spring Forward!!!
By MrMasterCraft in forum Almost Anything GoesReplies: 8Last Post: 03-14-2010, 11:26 AM -
looking forward
By Bugaboo in forum New Member IntroductionsReplies: 1Last Post: 09-12-2007, 09:10 AM
