Results 1 to 1 of 1
Thread: Help needed
08-29-2007, 11:21 PM #1
- Aug 2007
- South Africa
Help needed
I recently acquired a relatively new LS1 motor from Turn Key Engine supplies as well as an LS1 from a 1998 Camaro. The accessories on the Turnkey motor are similar to the Truck engine. My plan is to use the accessories (alternator, power steering pump, aircon waterpump etc) from the Turnkey engine on the Camaro block and visa versa. The problem is the pulley system on the Turnkey motor has a different offset from the motor (approximately 20mm further out) to the camaro motor. Ie. the crank pulleys have different offsets. the question is, can I simply remove both crank pulleys and swap them around with all the accessories or are the pulleys matched/balanced to a particular crank.
Any assistance will be appreciated.
Question: help needed
By 2000ls1tranz in forum Suspension and HandlingReplies: 4Last Post: 09-08-2010, 03:21 PM -
LS1 needed
By 1998 T/A in forum Parts Wanted / TradeReplies: 1Last Post: 07-29-2010, 10:38 AM -
Help: help needed
By hubba-bubba in forum General HelpReplies: 3Last Post: 04-13-2009, 03:52 PM -
Much Help Needed!!!!
By fuelslut in forum Internal EngineReplies: 5Last Post: 01-14-2006, 06:47 PM
