Results 1 to 17 of 17
Thread: sideways in the snow
12-09-2010, 12:05 PM #1
- Apr 2010
- scottown ohio
white- 2000 camaro z28
I just purchased a set of 1991-92 16 inch Z28 wheels cheap. I was wanting to mount the back wheels on my 2000 Z28 for snow purposes. Does anyone know if they will fit? Thanks for the help.
12-09-2010, 01:28 PM #2
I'll be the first to ask----- Why are you doing this? Is this your DD?
I ask because driving our cars in the snow is just asking for it to get totaled.
I can understand if its all you got but still......
Now to answer your question.
I believe the bolt pattern is the same but the spacing is slightly different.
have you tried to match them up to see? (bolt pattern)
12-09-2010, 04:46 PM #3
- Nov 2010
- MI
MMM- 2000 Camaro Z28
I believe the backspacing is different, and I know that the hub is slightly larger on LS1 cars vs LT1. I don't know if this is true for a 3rd gen rear or not. If it is, a dremel and 5 minutes is all it require to fix it. WARNING: DO NOT pull the wheel on with the lugnuts as you won't be able to get it back off. I've heard of people doing this and it is a nightmare.
Edit: You have to remember SMWS6TA, we from the Midwest understand how to drive in the snow :wink: Well, most of us. lolhttp://i261.photobucket.com/albums/i...IMAG0042-1.jpg
2000 Monterey Maroon Metallic Z28
M6, BBK Longtubes, SLP lid, Hooker catback, 17" Chrome ZR1s, Hotchkis springs
1996 Saturn SL2-DD status
12-11-2010, 06:44 AM #4
They will work..
Also to the dremel thing.. The lug nuts hold the wheel on, the center holds/bares the vehicles weight that's why it's machined to a certain tollerance to fit over the axle center. I would not take a dremel to a wheel center.. Ever..Last edited by Smittro; 12-11-2010 at 06:47 AM.
12-11-2010, 08:38 AM #5
- Nov 2010
- MI
Sometimes that is true sometimes it isn't. Depends on whether the car is hubcentric or lugcentric. Our cars are lugcentric, so the wheel has nothing to do with it. Look at all the aftermarket wheels. If what you are saying is true they would make different wheels for LS1 and LT1 cars.
12-11-2010, 10:18 AM #6
Center Bore
You're right, except we are talking about wheels for a 4th gen f-body.. I'm a 4 time f-body owner 89 thru 01. They are NOT "lugcentric" they never were tho they do use a lug centric type lug nut.. It's an s10 style rear which are also NOT lug centric.. lt1 and ls1 cars and 3.4l/3800-II f-bodies ALL have the same pattern spread. Again, Non of which are lug centric.. The lug studs are soft on these cars and were never intended to support the 3600 or so pound vehicle alone from their sides nor its power..
12-11-2010, 05:17 PM #7
- Tulsa,OK
Quick Silver- 2002 Z06
My formula with All Weather BFG's on the back got around in the snow just fine here in OK.
We don't get too much snow though and its never that tall.
Camaro Owners Click Here
Firebird Owners Click Here
www.AutoTrix.net
12-11-2010, 10:07 PM #8
ASR
Agree. Imho. As long as you have ASR or the equivalent and let it do it's job by not over powering it, they actually go pretty good. My 95 v6 however would get stuck just looking @ snow.. It did'nt have anything except the (one legged get out and push), leave it till day light option..
12-12-2010, 06:03 PM #9
12-12-2010, 06:30 PM #10
My 98 A4 TA was a dd year round and never crashed it. Although the 3.23 performance pack didn't help. Got sideways a few times but.usually was.control able. I ran the stock chrome 16's with the crappy Goodyear tires it came with. Buy nice winter tires for the wheels sure.it won't be great but it will help a little. Not sure if those rims fit but you can usually find stock 16's from the newer years for next to nothing. My chrome 16's were peeling but still good to drive one and I sold them with 2 good tires for $80.
12-12-2010, 07:47 PM #11
12-12-2010, 09:34 PM #12
12-12-2010, 10:42 PM #13
12-13-2010, 09:28 AM #14
12-13-2010, 09:44 AM #15
12-14-2010, 04:03 AM #16
- Apr 2010
- scottown ohio
Thanks for all of the help. I went with 225/60-16 snow tires with studs. The narrower tire made up for the different offset. The car does handle a little quirky due to the 245/45-17 front tires, but I am not looking for speed in the snow covered roads here in rural Ohio. I usually drive my rear wheel drive v-8 truck and Camaro year round and like the feeling of being sideways and having a good excuse to tell the state troopers when the snow is covering the roads. My Z28 is a rebuilt car and is not a garage kept show stopper like a lot of the Camaros and Trans Ams on this site. Maybe someday. Thanks again for all of your info.
12-17-2010, 01:27 PM #17
F*ck me sideways
By FSANE in forum Almost Anything GoesReplies: 62Last Post: 05-18-2010, 06:21 PM -
GTO's in the snow.
By Johny Utah in forum Almost Anything GoesReplies: 25Last Post: 10-06-2009, 01:42 AM -
1st gear sideways!
By Too Fast in forum Firebird / WS6Replies: 33Last Post: 11-06-2007, 05:17 PM -
Anyone ever heard of LS1 lifter turning sideways?
By 2001hawk in forum Internal EngineReplies: 7Last Post: 03-22-2007, 04:46 AM -
what do you think of the whole hat sideways look
By issues in forum Almost Anything GoesReplies: 63Last Post: 03-06-2007, 09:57 AM
