Results 1 to 20 of 29
Thread: green or red antifreeze
02-12-2008, 04:24 PM #1
- Oct 2007
- EDEN,NORTH CAROLINA
RED- 1999 FIREHAWK
I want to know if I can put green antifreeze in my 2001 trans-am and 1999 firehawk it has red .My 1994 trans-am has green antifreeze I put in it .I want to know if it will mess up my 2001 and 1999 trans-am if I put green in it .I have seen 1995 to 2000 chev goose neck pited out we change them to green no more problems. just wondering [thank]
02-12-2008, 09:19 PM #2
You need to put whatever color it currently has in it back in, most likely it will be red.
02-12-2008, 10:26 PM #3
there is pros and cons to both but imo i like the green .thats one of the first things i did when i bought my ta was change it to the green..your not going to mess up anything. its cheaper then buying dexcool . if you do change it over make sure you clean your cooling system really well..
02-12-2008, 10:28 PM #4
Yeah, mixing the two is very, very bad
02-12-2008, 10:30 PM #5
yup that it is thats why its really has to be clean before you do it
02-13-2008, 03:49 PM #6
- Nov 2007
- SATX
Pewter- 2000 Trans Am
the red one supports higher temperature, and the green one supports lower temperatures. but it is a bad thing to mixthem due to their chemical signatures.
02-13-2008, 03:56 PM #7
DEXCOOL 100% all the way, the Orange shit is good I did a Waterpump change, not a single sign of rust or dirt in the coolant, its very good. Plus having an aluminum block its importiant you use the proper stuff or you can have corrosion start to build up.
02-13-2008, 03:58 PM #8
- Nov 2007
- SATX
there's an orange one?
02-13-2008, 04:19 PM #9
Red, orange same thing. Dexcool is ok, but green is cheaper and works just fine.
02-13-2008, 04:49 PM #10
I don't care, when it comes to quality and taking care of my car i always make sure I use the best stuff.
02-13-2008, 05:02 PM #11
I personally have never seen a test where it says that dexcool is any better than green stuff, other than it is supposed to last longer, and its embittered so animals don't drink it. I don't care about it lasting longer and I don't leave it around where animals can drink it, so its just a waste of money for me.
02-13-2008, 05:30 PM #12
doesnt the green stuff cause corrosive wear on aluminum??? Im pretty sure I read that somewhere.
02-13-2008, 05:34 PM #13
Not that I've ever heard, though I have heard if you don't get all the air bleed out of the dexcool when replacing it, it will react with the air and corrode.
02-13-2008, 05:40 PM #14
02-13-2008, 05:48 PM #15
02-13-2008, 08:41 PM #16
- Sep 2005
- TEXAS... U mad?
Black / Stryker Blue- 2K WS.6/ 2K9 G8GT
+1 on the aluminum rot!!! DEX-COOL is the only way to go...
stay away from green...IT WILL CORRODE YOUR ENGINE
02-13-2008, 08:42 PM #17
- Sep 2005
- TEXAS... U mad?
mixing they two is very bad...
02-14-2008, 07:53 AM #18
- Nov 2007
- SATX
not only the red antifreese or Dexcool is better, it doesnt break down as easily as the green one when heat is at peek. We used the red antifreeze on all of our diesel engines, its just better performing.
02-14-2008, 02:34 PM #19
Dexcool ONLY!!!!!!!! I read 4 pages at work on why you should use what the OEM rec are. I would flush it every few years to avoid any problems. That 100,00 mile change interval is BS.
02-14-2008, 02:39 PM #20
- Nov 2007
- SATX
I flush mine every two due to the heat here in texas, but naturaly its every five years DOWUL
antifreeze
By V8MUSCLE in forum Almost Anything GoesReplies: 23Last Post: 02-17-2010, 05:32 AM -
Leaking antifreeze
By BlackbirdRamAir in forum External EngineReplies: 2Last Post: 02-10-2010, 03:08 AM -
Antifreeze...
By guitarjay76 in forum General HelpReplies: 3Last Post: 06-07-2009, 07:27 AM -
Low antifreeze level
By trans.am in forum General HelpReplies: 5Last Post: 03-24-2008, 02:46 PM -
Antifreeze smell
By repeter in forum GTOReplies: 0Last Post: 05-21-2007, 06:32 PM
