Results 1 to 2 of 2
Thread: Volt Problem
06-06-2008, 08:50 PM #1
- Jan 2007
- Inman, SC
Navy Blue- 1999 Z28 LS1
Volt Problem
ok ive got a 99 z28 camaro. I have replaced the battery with an optima red top and a brand new alternator. My volts gague will go into the red when sitting at the red light with the a/c on and the radio is barley on. I hava an amp, a 12" sub , a capaciter and a kenwood kvt-617 dvd player with the 7" touch screen. it done the same thing before and after the amp and battery swap. wat could be wrong i need somewhere to start or is it normal.
06-07-2008, 04:50 AM #2
Start your car and put a volt meter on your alternator and confirm your getting 14.4VDC.
Check to make sure you have the correct alternator in place.
Check for grounds or shorts.
Which can be a pain in the arss.
Volt Gauge?
By pajeff02 in forum GM TrucksReplies: 5Last Post: 11-19-2010, 10:22 AM -
GM Lied About The Volt?
By CJREX in forum Almost Anything GoesReplies: 45Last Post: 10-14-2010, 04:32 PM -
Volt Question
By 1993ta in forum General HelpReplies: 3Last Post: 10-13-2007, 09:03 AM -
VOLT gauge is almost at red need help?
By greatwhiteZ28 in forum Camaro / SSReplies: 2Last Post: 02-11-2007, 02:25 PM -
16 Volt ?'s
By wildkatz in forum Stereo and ElectronicsReplies: 1Last Post: 06-26-2006, 09:59 PM
