Thread: Stock Air Lid
11-17-2022, 10:49 AM #1
- Jun 2011
- washington
red- 2002 pontiac trans-am
Stock Air Lid
i would like to keep my T.A as stock looking as possible. is there a way to hollow out, or redesign the stock air lid to make it perform like an aftermarket one?
11-20-2022, 10:52 AM #2
What you are looking for is commonly called the Free Ram Air Mod. By making some small trims to the bottom of the air box you can introduce air flow from the under the car into the air box when the car is moving. Some will argue that this will increase air temperature at the intake because the air passes over the radiator. I've never seen any actual reliable testing to show an improvement, but it is very common and SLP also had a kit that included a stainless-steel funnel that would mount below the air box and included the same mod. The funnel theoretically eliminated the heating from the radiator. There is an excellent write-up at www.InstallUniversity.com . Once you get into the site (it is no longer maintained and is becoming flaky so if you get it, grab copies of everything that looks interesting before it goes away), click on Install Documents then Free Ram Air.
11-20-2022, 03:06 PM #3
- Nov 2006
- Indianapolis
Or, one could internally eliminate the internal baffles so the airflow is cleaned up. Basically what the aftermarket lids do, losing the turbulence that the silencers added. A proven, easy 5-10 HP gain.
11-21-2022, 11:40 AM #4
- Jun 2011
- washington
11-24-2022, 06:23 AM #5
Simplest way to achieve what you want without any permanent modifications is to just replace the stock lid with an aftermarket. They are not all equal as some are better at sealing to the air filter than others. You can pick up an SLP or other used lid pretty reasonably on ebay or other sale sites. The best aftermarket (OEM on Firehawks and some SLP SS cars) lid in my opinion is the Donaldson Blackwing lid. It has all of the engineering and excellent fitment of an OEM lid and will work as good or better than any of the others along with near perfect fit and sealing on the air filter. Downside is, they are hard to find and very expensive ($300+).
11-25-2022, 07:06 PM #6
- Jun 2011
- washington
thanks
Stock headers, stock (GM) cats, y pipe custom fitted for LM1
By az gt eater in forum Parts For Sale / TradeReplies: 2Last Post: 11-20-2011, 08:26 AM -
LS1 Intake,Throttle Body, Gaskets, EGR, AIR, Stock Lid, Stock Manifolds
By WEZONIT in forum Parts For Sale / TradeReplies: 13Last Post: 10-11-2007, 12:48 AM -
FS: Stock 4-16x8 polished rims w/ stock eagle tires
By Long Beach in forum Parts For Sale / TradeReplies: 4Last Post: 01-24-2007, 10:11 PM -
By Long Beach in forum Western MembersReplies: 1Last Post: 01-24-2007, 09:15 PM
