Results 1 to 20 of 23
03-15-2010, 04:49 AM #1
- Oct 2009
- The Woodlands/spring/houston
pewter- 99 trans am
a couple of pics of what i did this weekend.
So after 2 days of getting dicked around by car salesmen, I decided to just take my money and put some into the vette. I always thought a carb and intake would wake it up a bit. I found out a lot more than expected. I bought an edelbrock 600cfm manual choke carb, edelbrock intake (idle-5500rpm), and a few chrome goodies to make it look ok. So the swap went well, fixed some oil leaks that were lurking around, and tried to get rid of some of the excess wires and hoses. For a while, I thought i had a busted piston ring because i was blowin blue smoke like a mofo. Turns out it was my pcv valve stuck, so i replaced that also. After my engine building friend tuned the carb and timing, the car had a very distinct lope and revved out with the quickness! My friend looks at me and says "mike, this cam in this car aint stock." I said
.....apparently the stock intake and quadrajunk were hindering any idea of it having a bigger than stock cam. If there is a bigger cam in there, its not much bigger. Anyways the engine looked really clean which was expected since it was rebuilt 2 years ago and sat for a year and a half of that. So other things that need to be replaced are motor mounts (driver side is broken, cant even dog the car right now
) also gotta do some suspension work and i plan on pulling the engine and cleaning the rest of the shit out of the engine compartment. Oh and new heads cause apparently the heads i have are the shittiest ones ever, casting# 462624
I screwed up and forgot to take pictures before i disassembled.
as you can see here there still needs to be a lot of extra crap removed from the engine compartment.
03-15-2010, 08:15 AM #2
- Jan 2008
- heart of dixie
06 Jeep Grand Cherokee.- 02 superchipsZ28 M6(sold)
good project, yeah the smog crap(i think) needs to go. those heads are 462's didnt think they where awful heads used a set before. she needs vortec's ! got any more pics of her ?
03-15-2010, 08:28 AM #3
- Oct 2009
pewter- 99 trans am
well the only 462's i know of that are good are the ones that the casting # ended in 462.....the heads i have are #462624..1975-86 350/400 76cc chamber, 1.72/1.5
just basic gm heads that were used on most of their low hp engines...you can see the intake ports are totally bullshitt..needing ported..plus these castings are known to crack between the valve seats, even without modification.
The heads you are talking about may be these
casting number
3767462....62-67...327
462 62cc 1.94 1.50
462 63cc 2.02 1.60
I will take more pics later today as i have realized i forgot to add a secondary fuel filter before the carb. this weekend may be the weekend the engine comes out for total clean up and maybe even throw on the double hump heads...
03-15-2010, 08:30 AM #4
03-15-2010, 08:43 AM #5
Looks and sounds like a big improvement. I am still chasing an idle gremlin on ours with the Quadrajet.
03-15-2010, 08:47 AM #6
- Oct 2009
pewter- 99 trans am
i swear man when i put that new carb on there, it ran like a new machine. There was no more hesitation in the throttle, which even when warmed up, the quadrajet always seemed to hesitate. i think those heads are really slowin me down though. All together this stuff costed me about $575...and that included gaskets and valve covers. add another $20 for the oil change.
ive been neglecting the car and didnt even realize it. to think i almost swapped the engine thinkin i had a busted ring.
03-15-2010, 02:41 PM #7
I remember there being huge difference when replacing the Quadrajet with a Holly 600 and throwing on an Edelbrock high rise performer. Perked my car right up
03-15-2010, 02:54 PM #8
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
Looks good. It's funny how you really gotta have things matched up to get the performance and when you don't it really makes a difference.
Is that a foam air cleaner? I always heard they were no good - backfire would cause the foam to melt and drip in the carb. Don't know if it's true or not though.
Can't wait to see more pics too!It's not how fast you can go. It's how fast you can get there.
03-15-2010, 06:07 PM #9
When I started the restoration, the car had a Holley "Q-jet replacement" carb. I rebuilt that to get it running, but wanted to go with a Q-jet as that is what the car originally came with. Also, the stock air cleaner only fits Q-jets which makes swapping to a different carb next to impossible. The idle issue has to be something seriously stupid that I am just not thinking of.
03-15-2010, 06:30 PM #10
When I did the Chevelle, the carb and intake were the first to go. I didn't care about the stock air cleaner. I wanted it gone.
But, when I had the block done, I did wait an extra two weeks to get mine back. I wanted the numbers to match. Other then that, I wasn't going for stock anything.
Boy, that seems like a lifetime ago. Heh... actually, it was.
03-15-2010, 08:32 PM #11
- cleveland ohio
trans am 00 ws6- 1998 camaro ss vert
looks like your starting to get there. i still have a bunch of parts heads cam ect. pm me if you need something.
03-16-2010, 03:26 AM #12
The quadrajunk was good for mean sounding secondaries and not much else.. Any engine with a Q-jet from the era is starving for fuel. Eddies are the way to go imho on a sbc.. Adding the eddie intake was a good choice too as you prolly already know. But to get any sbc to run good just have to make them breath. Oh and the cam thing there could be a cam in it but the pop and crackle is just how chevy sbc's run naturally with just about any stock cam and a good set of headers and a carb. I built a old sbc all stock for a 78 blazer once. Fired it up open headers and you would have sworn on a stack o bibles it had a huge cam, popping and crackling, flames if you goosed it and such. Nothing runs like an sbc imho.. Some of the truck motors such as what was found in old wreckers with 4 bolt mains and a steel crank were screamers strait out of the box. Get yourself a set of 2.02 camel back castings and that motor will surprise you.. But it would'nt surprise me if it does have a mild cam either. Those smoggers were known to chew their stock cams down almost to the base circle. If they had a real restictive exhaust sometimes the bad cam would'nt show its ugly face till you added headers and opened up their pipes. Then they'd misfire all over the place unless you floated the valves. Looking good man! Love that square bore long stroke growl..
03-19-2010, 12:14 AM #13
- Apr 2006
- park bench
- gmcheviac
03-19-2010, 12:19 AM #14
- Apr 2006
- park bench
- gmcheviac
mine lopes slightly, 2-1/4" duals through magnaflow bullets, no crossover (not my choice), longtubes. Performer mani. and richer than stock rebuilt rochester. Plenty of timing and vacuum advance off of the manifold. you'd swear it's cammed but it's just a fresh goodwrench with a 194/202 or so flat tappet. I think the lean-ness of the quad is part of it, lean makes for some chop at idle I believe. I need to play with my idle mixture screws
03-19-2010, 01:56 AM #15
03-19-2010, 03:45 AM #16
03-19-2010, 03:47 AM #17
03-19-2010, 03:51 AM #18
03-19-2010, 03:55 AM #19
03-19-2010, 05:10 AM #20
Couple new pics of the hot rod....
By xssv in forum Appearance SectionReplies: 14Last Post: 12-06-2014, 05:37 AM -
just a couple of funny things from the weekend
By jiveass in forum Almost Anything GoesReplies: 0Last Post: 07-06-2010, 05:08 AM -
Couple new pics
By MaxPlusTen in forum Firebird / WS6Replies: 6Last Post: 10-31-2008, 01:38 PM -
Took a couple pics of the WS6
By F-Body Man in forum Firebird / WS6Replies: 18Last Post: 06-28-2007, 01:32 PM -
Couple New Pics of My '01 Z28
By Demon_Speeding in forum Member's RidesReplies: 7Last Post: 09-03-2005, 03:05 AM
