Thread: Need some advice
10-20-2010, 07:30 AM #1
Need some advice
Okay the other day I changed out all spark plugs and wires plus both 02 sensors. Okay well ever sense then my car has trouble starting up in the morning. The car will fire then sputter and die, I have to turn the key off and try it again holding the gas a little to keep it from dying. It only does it in the morning and after that its fine durning the day. Iam thinking maybe fuel pump and ill get the pressure checked today. What is the fuel pressure suppose to be at and do I check it before I turn the key and after I turn the key???? Thank you
10-20-2010, 07:46 AM #2
- Jul 2010
- Pittsburgh, PA
Navy Blue- 1999 Camaro Z28
10-20-2010, 08:06 AM #3
Why did you change plugs and o2's? Were you having a problem before or just maintenance?
10-20-2010, 09:07 AM #4
Ya i was throwing codes for the o2 and the plugs i just did because i havent done them since i did the headers.
New, need advice.
By tomscamaro00 in forum New Member IntroductionsReplies: 5Last Post: 04-05-2010, 06:26 PM -
Need advice, possibly legal advice
By JHayesLS1 in forum Almost Anything GoesReplies: 36Last Post: 12-19-2009, 09:23 AM -
Need serious advice...alot of advice. Long.
By !!!FAST!!! in forum Almost Anything GoesReplies: 0Last Post: 10-31-2007, 07:49 PM -
Hello, and need advice
By jpwamt in forum New Member IntroductionsReplies: 4Last Post: 12-19-2006, 07:18 PM -
Need ADVICE
By dblanch35 in forum Automatic TransmissionReplies: 1Last Post: 12-16-2006, 10:56 AM
