Results 1 to 1 of 1
Thread: Cold Start Issues
08-29-2022, 11:49 AM #1
- Aug 2022
- Ennis Texas
Black- 1968 Chevrolet C10
Cold Start Issues
Maybe someone can help me out here before I pull all my hair out. I have a 68 C-10 pickup LS Swap. I have an issue after you let it sit for 2 or 3 days it takes forever for it to crank and then when it does finally crank, it runs like crap for almost 5 minutes. It has a "Tanks" fuel tank under the bed with the corvette style regulator/filter with a return line to the tank. I just put an inline gauge at the rail and have 58 psi when I turn the key to the "on" position. I have tried changing plugs, regulator/filter, maf, and everything else. I had a tune on it from a very reputable shop but no luck there. But when it warms up, it runs awesome. It is a fairly stock LS with a fabricated sheet metal intake on it but that is about all. I'm thinking it is a mechanical issue and not a tune issue but not 100 percent sure. Not sure what to do here?
Issues When Starting In The Cold
By surfinjoe in forum GTOReplies: 11Last Post: 01-26-2009, 09:05 AM -
Cold Start-Up
By jz28 in forum Camaro / SSReplies: 19Last Post: 04-10-2008, 02:40 PM -
Cold Start/Warm Start Problem
By I'mLS1John in forum General HelpReplies: 11Last Post: 02-23-2007, 07:11 PM -
By I'mLS1John in forum New Member IntroductionsReplies: 0Last Post: 02-22-2007, 05:26 PM -
Cold Start problems?
By SteveCZ28 in forum General HelpReplies: 3Last Post: 12-16-2006, 06:54 AM
