Results 1 to 20 of 31
07-24-2011, 08:08 AM #1
I wanna buy an 04-07 CTS-V? Pro's and Con's?
I am interested in an 04-07 CTS-V. Can you suggest which year I get?
Any issues you know of or have heard of and is there a fix available?
Thanks
07-24-2011, 10:59 AM #2
The early ones have rear dif issues but not all of them, like the 10-bolt it has good and bad stories.
04-05 is the LS6 and the later years are LS2 so not sure which you would prefer. Some like th LS6 more where as some want the LS2 but it really wouldnt matter to me.
There are some decent deals on those right now.
07-24-2011, 02:26 PM #3
if you get one with the ls6 most of your fun parts should bolt right up
07-24-2011, 05:47 PM #4
- Apr 2008
- Madison, WI
Yep, the rear end is about as good at the 10 bolt in the F-body, except it'll cost you alot more to fix it. And I don't think there is an aftermarket solution for a stronger rearend, so if you wanna upgrade it, it'll have to be a custom fab job. Otherwise, they are pretty cool cars. You get those big ass cool looking Brembo brakes!! And I can't really think of any common PITA problems with them besides the rear end.
07-24-2011, 06:40 PM #5
- Feb 2010
- Greenwood, IN
Light Pewter Metallic- 2001 Camaro SS
The rear ends are weak because of the wheel hop the car experiences. change out the axles and from what i have read it eliminates most if not all of the problem. the motor mounts seem to go bad quickly so that is something to be careful of and a lot of the people have experienced easily chipped nav buttons. I know that mine was replaced about 2 years ago under warranty because of this. I absolutely love my V. It is an amazing car to drive.
07-24-2011, 07:15 PM #6
Chipped navigation buttons? What do you mean?
2004 SILVER CTS-V sittin on H&R Springs / KOOKS 1-7/8 LTH's/Corsa Cat-Back/COMP CUSTOM GRIND CAM(.613/.620)/TRICK FLOW HEADS
TUNED BY RACE PROVEN MOTORSPORTS
R.I.P. 505 RWHP PROCHARGED 98 SS
07-24-2011, 07:16 PM #7
I know all about the rears. It seems the Fab 9 is the only fix so far but it costs $5k, haha!
07-24-2011, 07:18 PM #8
Yeah, the TFS heads and Centerforce clutch should bolt right up.
07-24-2011, 07:22 PM #9
07-24-2011, 07:26 PM #10
Can you replace them yourself?
07-24-2011, 07:34 PM #11
07-25-2011, 06:00 PM #12
My damn Jeep has a button that is chipping...................send a man to the mood but we cant have a plastic button that wont chip?
07-26-2011, 03:25 AM #13
- Apr 2008
- Madison, WI
Yeah the paint coming off the buttons is a problem industry wide (GM, Ford, Chrysler, Toyota, etc). It can be minimized or avoided if you're hands are clean and you're gentle with the buttons. I've heard that lotions/sunblock/etc accelerates the problem. Hopefully they eventually develope a better paint someday.
07-26-2011, 11:44 AM #14
07-26-2011, 01:45 PM #15
- Feb 2010
- Greenwood, IN
all I have to say is buy a V. you will not be disappointed.
07-26-2011, 03:15 PM #16
The V is badass, but I will still be yearning for more the day I pick it up. I test drove a black V with tan interior last Saturday. I was hooked as soon as I pulled in the parking lot and saw it.
Now comes the disappointing part. >> The acceleration. By no means is this car slow, but you gotta remember what I got out of. My Camaro made over 500 RWHP. I used all 500 RWHP everyday so I am going through some serious withdraw right now. I could pull out into traffic and hit 60 in like 3 seconds, and I could short shift it to achieve this kind of acceleration. It was a monster, even in 6th gear. I guess I already miss it pretty bad and I'm still pretty upset. The V will never be what the Camaro was. I guess I feel like I am forever out of the game.
I know the Trick Flow heads will fit but I need to figure a way to hook up the Procharger as they don't make a bolt-on kit. A cam will be added at the same time.
I also need to see if my Quick Time scatter shield and Centerforce 12" clutch will fit? I know that the throwout bearing is mounted further out of the crank since the input shaft is shorter on the V T56.
Only thing is, I don't want to make the V like my Camaro was, which had a brutal ride and loud exhaust. I kinda like the way the V sounds and I love the way it rides.Last edited by 9t8z28; 07-26-2011 at 03:18 PM.
07-26-2011, 04:18 PM #17
- Jan 2009
- North Jersey
You might have to call ProCharger directly and ask if they can cross-reference the kit for the GTO with the V and see if the bracket for the GTO will bolt to the V. That way, you can take the blower from the Camaro and bolt it into the V.
07-26-2011, 07:47 PM #18
- Feb 2010
- Greenwood, IN
That is all understandable. There are a ton of Vs out there with Maggies. Sell the procharger kit and get yourself a maggie. You sir would then have an absolute beast. As far as the sound, cut off the rear mufflers and you will love the sound even more and I promise it isn't a trashy sound.
07-26-2011, 09:56 PM #19
I had a 2004 CTS-V which I loved performance wise. Biggest issue I had was when minor stuff went bad, like my climate control panel went bad and the dealership wanted $900 to fix it, which included 3 hours labor, I found one online for $35 with shipping, and had to removed 4 little screws to replace. Other then that it was quick and handled amazing. Just make sure you get rid of the skip-shift, can get really really really annoying.
07-28-2011, 06:46 AM #20
I wanna be the very best
By 86 IROC-Z in forum Almost Anything GoesReplies: 26Last Post: 08-18-2010, 12:51 PM -
You know you wanna
By SeVeReDiStOrTiOn in forum Almost Anything GoesReplies: 4Last Post: 07-11-2009, 06:22 PM -
Wanna know what's f'ed up?
By Another WS6 Guy in forum Almost Anything GoesReplies: 30Last Post: 03-10-2009, 10:41 PM -
I know we did this before but i wanna see again..
By Stone in forum Almost Anything GoesReplies: 20Last Post: 01-01-2008, 12:01 PM
