Results 1 to 20 of 23
Thread: new best et
09-21-2006, 10:11 AM #1
new best et
well i went to the track on tuesday at gateway and ran a 13.08 @107.88
wow i am very happy with my car it was 62 degrees out that helped and my mods are slp cai, magnaflow muffler, tb bypass, and thats it elevation is 280 ft i think
i was hoping for a 12.99 but it didn't happen, i prdered the 160 thermo and b@m shift kit, maybe i 2 weeks i can slide into the 12.9's,
future mods offroad headers, tune, msd wires,and ls6 intake, and later a 12 bolt rear with 3.73's over those 2.73'3 i have
why is my car running so fast , i ran against other SS's and WS6's they were in the 13.6 with 3.42 gears and lid, the ss had drag radials even but probably stock
09-21-2006, 06:34 PM #2
- Sep 2006
- Central,Texas
Navy Blue Metallic- 2000 Camaro Z-28 SS
You have 2.73's...I am impressed that you ran that with those mod's! I am guessing you have a lid as well. Either way, good time's for a 2000 w/a ls1 intake and 2.73's!!!
09-22-2006, 05:59 AM #3
yeah i do have a lid and cai, i dont know why my car runs so good, mayby it is just a factory freak, ran out of stock cams so they went with a high profile, lol but probably not
09-23-2006, 06:34 PM #4
My bud ran his bone stock T/A M6 with a 12.4.
It was in Baytown, TX So LOW elevation helped but its usually up to the driver.
09-25-2006, 01:52 PM #5
- May 2006
- England but from TX
Light Pewter Metallic- 2K Camaro Z28
Awesome times for lowly modded LS1/2.73s. I ran 13.1s @ 106.8 w/ my 2.73s but I have LTs/TDs/lid/free mods.
09-28-2006, 04:19 PM #6
- Aug 2006
- michigan
red- 2001 camaro
my 01 ss ran 13.3 stock up in michigan. you are one of the lucky ones.
09-29-2006, 09:30 AM #7
what do you mean lucky ones, was this car built in a certain way
09-29-2006, 09:39 AM #8
- Aug 2006
- michigan
red- 2001 camaro
no thats just what ppl up here would tell me cuz they thought my times were good. but yours are awesome.
09-29-2006, 09:51 AM #9
going to gateway in 2 weeks, new mods are, shift kit from b @m and it shifts hard, and i also removed all the emissions equiptment, that was 20 lbs, 160 thermo, not a whole lot but mayby those little things will push me intp the 12.9,s
20lbs is good foe .02sec, not much but every little helps
the shift kit is usually good for ..09
the thermo lets the car run cooler and less heat sink, so mayby a few extra pony's 2 or 3
my guess is with these mods i will run a 12.97 if temp and traction remain the same. will let you all know what i run
09-29-2006, 03:44 PM #10
Good luck. I havnt run my car yet. I hope to get low 13's.
09-30-2006, 07:01 AM #11
Thats a good starting point. Let the mods begin!
09-30-2006, 07:23 AM #12
- Aug 2006
- Tulsa, Oklahoma
Navy Blue Metallic- 2001 camaro SS A4
last night at the track I got a best of 13.82 @ 102. But I couldn't lunch the car! First try I put it to the floor and spun thru first and second while runnig a 15.91 @ 98 with a 10.879 1/8 mile.
09-30-2006, 09:05 AM #13
- Oct 2005
- Houston,Texas
white- 2000 Camaro Z28
I ran at Baytown 9-24-06 and ran a 13.2@106 The cooler temps helped.
See my sig for my modsMTI Clear Lid (Free Ram Air Mod Raised Air box) Larger MAF Ends,K&N Filter, SS Exhasut with cut out, rear Lower control arms,smooth bellows,12.894@107.10MPH Dynoed 316 HP (Before RLCA and smooth bellows) 8.3.12 @86.86 1/8th mile 121,000 miles
09-30-2006, 09:44 AM #14
- May 2006
LOL! Sorry to burst your bubble but the emission stuff is not 20 lbs. I took mine all off and it probably weigh less than 5 lbs. the heaviest is the AIR pump. The 160 stat is worthless until you add manual fan switch or program your computer to turn your fans sooner which what I did.
2K LPM Z28 M6- GMHTP StreetHeat feature Nov 12- Camaro Performers Readers' Rides feature Nov 12
2K4 BS G35 sedan 5AT
10-02-2006, 11:23 AM #15
sorry to burst your bubble numb nuts, but i weighed it all on a digital scale
and it wasn't 20 lbs it was 17.1
I weight the airpump, all air pump hoses, egr solenoid, and the CAST IRON bracket , the stainless steel tubing,
and i know at idle the thermo wont make much diff but when i drive there it will help the car stay cooler, and receive less heat sink
10-02-2006, 12:03 PM #16
10-15-2006, 07:49 AM #17
- Groves, TX
Sunset Orange Metallic- 1998 Camaro Z28
He's right about the thermostat...you have adjust the computer for 160 or it will still operate the same.
10-15-2006, 08:00 AM #18
- Sep 2006
- Central,Texas
Heat this, heat that. Just pop your hood and have a 20-30 min cool down period between run's. Have you thought about iceing down your intake? I was going to but the damn STB was in the way. So I just dumped the ice in the cooler. Do you take your jack and spare out while you are at the track? Every little bit help's.
10-17-2006, 03:05 PM #19
- Oct 2006
- waxahachie
mistic- 2000 chevy camaro
i have a 2000 camaro with a 3000 stall and 273 gears and ran a 13.00 flat at 101 it ran a 13.6 at 104 without the stall and with a venom kit that dont work half the time i got a best of 12.3 at 112
10-19-2006, 04:48 PM #20
- Oct 2005
- Lincoln, CA
Pewter- 2000 Z28 Camaro
My 2000 Z28 has a 2.73 rear end and is basically stock. I have a lid and that's about it. My quickest pass was 13.44 @ 105.75 mph and my fastest pass was 13.52 @ 107.43. Those gears really make for high trap speeds. If you are going to modify the car, you would probably get more bang for your buck by installing a stall converter than lowering the gear ratio. It would probably be better for street driving as well since the lower gears would jack up your rpm and use more gas.
