    Exclamation Drum Brakes on a 99 Taurus; wobble the car?
    Hey guys,
    My fiance's car's drum brakes wobble the car and shake the steering wheel pretty fierce when we brake anywhere above 60 mph. Thoughts?
    Single Malt rbob93's Avatar
    Ft. Lauderdale, FL
    Sebring Silver
    2000 CamaroSS
    Loose or bad steering components come to mind
    My guess is that the drums have nothing to do with the steering, as they'd be on the back of the car. Perhaps some SERIOUSLY warped rotors? Had a cousin with an Olds Alero that had a stupid-bad steering wheel wobble while braking, the rotors were way warped, needed replacing.
    San Diego
    2002 T/A
    Thumbs up
    +1 A lot of alignment shops offer free inspections. If the car's brakes have never been serviced while she's owned it I would get new brakes pads/shoes and rotors/drums and ask the mechanic to check for loose/worn suspension and steering components.
    Ft. Lauderdale, FL
    Sebring Silver
    2000 CamaroSS
    Well guess again
    http://wiki.answers.com/Q/Why_would_...g_wheel_wobble
    We're talking steering wheel shake I believe
    May be the rotors.....but with the age of the vehicle I would definately check for bad steering components
    Struts, tie rod ends, pitman arm, ball joints, wheel bearings etc.
    San Diego
    2002 T/A
    Quote Originally Posted by rbob93 View Post
    Well guess again
    I don't think anybody disputed worn out suspension components, as a matter of fact, I suggested that in post #4. Out of balance rotating assemblies such as bent or unbalanced rims would be felt regardless of brake application. I believe Zapper was referring to rear drums affecting steering wobble. The link you posted does specify front for most of its causes.
    Ft. Lauderdale, FL
    Sebring Silver
    2000 CamaroSS
    Quote Originally Posted by LS1_TA_2002 View Post
    I don't think anybody disputed worn out suspension components, as a matter of fact, I suggested that in post #4. Out of balance rotating assemblies such as bent or unbalanced rims would be felt regardless of brake application. I believe rbobb was referring to rear drums affecting steering wobble. The link you posted does specify front for most of its causes.
    I agree the drums are on the rear.....I felt we were missing the point of bad steering components as a possibility
    But it's not the first time I've been mistaken
    And my apologies if I appeared rash
    San Diego
    2002 T/A
    No harm no foul. I actually meant to use zappers name not yours, sorry.
    sounds like warped or chipped rotors. I've seen rotors have a chunk missing out them but if it's that bad you would be able to feel it at slower speeds. I would look at the front rotors first. Not that it can't be suspension components just that in my experience any problems you feel in the steering wheel when the brakes are applied are normally a front brake issue.
  1. Crankshaft pulley wobble. What to do?
    By SiskMan in forum General Help
    Last Post: 10-27-2014, 08:40 AM
  2. Iphone Wobble....
    By suede in forum Almost Anything Goes
    Last Post: 01-31-2009, 11:42 AM
  3. Crank Pulley Wobble Problem
    By Nero.Jacinth in forum Internal Engine
    Last Post: 10-07-2007, 09:08 AM
  4. drum brakes are the devil..
    Last Post: 09-21-2006, 07:20 PM
  5. Drum Brakes On a 97 Honda???
    By Blown Interceptor in forum Western Members
    Last Post: 11-23-2005, 01:37 PM
