Results 1 to 20 of 60
Thread: What New speakers?
04-10-2006, 01:36 PM #1The RookieGuest
What New speakers?
The passenger side door speaker is blown. Without having to buy new or used Monsoon speakers, What speakers can I put in the doors that will work with my stock monsoon system and sound great?
04-10-2006, 02:09 PM #2
If your looking for cheap and good, I'd recomend the Rocksford Fosgates (Model#T162C). They sound AWESOME!! Nice and clear and good bass. I paid $150 for a set at BestBuy.
If your looking for high end, White Rascal, can recomend something better.
RobLast edited by graphicsgod; 04-10-2006 at 02:20 PM.
04-10-2006, 02:44 PM #3
Infinity kappas, i just got a pair off ebay for $92 shipped.
04-10-2006, 03:28 PM #4The RookieGuest
Great........ thanks guys!
04-10-2006, 08:41 PM #5
Infinity Kappa 62.7i's.. Unless you want to find another brand and modify it to make a seperate input for a tweeter. The Infinity 62.7i is the only choice you have if you don't want to modify it at all and is 2ohm like the stock speaker. Just don't use the crossover supplied with it, connect it just like stock. The Monsoon door speakers on the Camaro have 2 inputs(1 for the woofer and 1 for the tweeter) so any speaker will not work. The woofer is powered off the monsoon amp and tweeter off the headunit.
04-10-2006, 09:41 PM #6The RookieGuest
thanks rotwiler
04-11-2006, 05:32 PM #7
- Apr 2006
- yuma arizona
silver- 1998 Z28
is my car the only one with 4" speakers in the rear? i thought they were 6.5 all around.. wtf?
04-13-2006, 07:58 AM #8
far rear hatch speakers are 4inch full range 4 ohm speakers and run only off the headunit in the Camaro.
04-14-2006, 12:31 PM #9JPNNHGuest
I just had BestBuy install their Kenwood for $69...They are great & cheap too!
04-15-2006, 09:34 AM #10The RookieGuest
Bought the Infinity Kappas 62.7i's on line for 100 bucks including shipping. Should have them Monday. I'll let you know how they sound.
04-15-2006, 09:03 PM #11
Remember, do not use the crossover, connect them direct. I'm sure you will be happy with the sound.
04-19-2006, 07:05 PM #12The RookieGuest
They sound good and thanks Rot I figured I wasn't supposed to use the cross over. They sound great! Now i have the stereo bug though and want to upgrade the whole system. Throttle body, gears and cam are coming first though.
04-19-2006, 08:06 PM #13
- Apr 2006
I'm a Rockford Fosgate fan, Pioneers can be good too.
04-21-2006, 03:03 PM #14
- Nov 2005
- Cypress, Texas
Burple- 1966 427 Cobra Replica
Wait, so that Infinity speaker will just hook right up to the stock speaker's connection?
04-21-2006, 04:53 PM #15
Yep, and they sound good too! The 62.7i is dual input like stock.
Originally Posted by Tobynine9
04-21-2006, 09:23 PM #16
- THE SWAMP
Good info here...both my door speakers are now blown and I was looking for a good replacement that would work with the stock monsoon system. Thanks.
04-21-2006, 10:39 PM #17
As far as I know...and I have researched this alot, the Infinity 62.7i and 63.7i is the only speaker that is a dual input 2 ohm direct replacement for the 98+ Camaro..not sure about the 97. There is a model of 4ohm Alpines that work with a little mod to the tweeter to make it work. The Pontiac cars have components, so there are more options, but they still need to be a really efficient speaker to work well with the Monsoon amp. I like the 62.7i's and very happy with the sound quality. They were released in 2005, so before 05 there were very limited options(basically the Alpines were the only choice or components). I have the 62.7i's in the sailpanel too, but I am running a seperate mtx amp and 2 memphis 10's, so I am not trying to get bass out of the 62.7i's. Most car audio shops don't have a clue about the Monsoon setup, even crutchfields says the 62.7i doesn't work with the stock system. Then when car audio shops see the dual inputs they normally connect the single input speaker to tweeter input since it is full range. Then you are not using the Monsoon amp at all and losing out on power. Since the tweeter is powered only off the headunit in the front doors and the woofer is powered only off the Monsoon amp it makes a big difference if you don't use the correct speakers. I have no plans on removing the Monsoon amp, I think with the Infinity's the Kenwood x790 hu and the 2 10's it sounds excellent.
04-21-2006, 11:02 PM #18
Alpine SPS 170-A
Really cheap...dont distort at high level...bad thing is that they are 4 ohm... pretty decent speaker... I enjoy them!
04-22-2006, 10:37 AM #19
- THE SWAMP
Originally Posted by rotwiler
05-01-2006, 10:35 PM #20
- Feb 2006
- S.C
Pewter- 1999 Camaro
I have a 99 Camaro without the monsoon setup and want to replace the speakers in my doors and in the back seat would the Infinity 62.7i fit in both the doors and the rear without any modifications, and do you think they would sound good without an amp pushing them?Last edited by Maro99; 05-01-2006 at 10:37 PM.
Question: Sail speakers and rear speakers
By TJKIDD in forum Stereo and ElectronicsReplies: 7Last Post: 06-01-2011, 04:21 PM -
Question: Difference between car speakers and home speakers?
By Kedwin in forum General HelpReplies: 3Last Post: 10-05-2010, 04:11 AM -
PC Speakers....
By Mr. Luos in forum Computers / GamingReplies: 2Last Post: 08-12-2009, 10:33 AM -
Speakers
By axcellclan in forum Parts Wanted / TradeReplies: 5Last Post: 03-16-2007, 04:58 AM -
Car speakers
By GottaHaveLS1 in forum Stereo and ElectronicsReplies: 28Last Post: 12-28-2006, 02:37 AM
