Results 1 to 3 of 3
07-30-2008, 10:21 PM #1
Guys Me Powersteering Pump Cooler Mest Up!
My Ps Pump Cooler Mest Up So I Ran A Hose Instead You Think It Will Mess Up The Car Or Is It Okay Just To Leave The Hose Instead I Have A Ls1 Camaro Ss 2000 Manual THIS IS WAT MEST UP IN MY SS!
07-31-2008, 02:00 AM #2
- North Olmsted, OH
Navy Blue Metallic- 2000 Camaro Z28
What do you mean by mess up? Clogged, leaked or what? No you don't need per say but it does help keep the power steering fluid a bit cooler which helps the longevity of the pump. If the car is just a daily driver it is probably ok. My car didn't have one and was fine until I started racing it in Autocrosses and Road Courses the pump went so I put one in along with the new pump.
2000 NBM Camaro Z28
Mods:
SLP Lid & K&N, AHR Headers + 3" catted Y and Mangaflow, !EGR, !AIR, BMR CM STB, ST Front 35mm and Hellwig Adj. Rear 22mm Swaybar, Adj. Rod/Rod PHB, Koni SA's, Ground Control Springs & Adj. Ride height, and HPTuners.
07-31-2008, 02:03 AM #3
Oh Okay Thanks Bro!
PS PUMP & PS Cooler and my findings
By TerribleTed in forum General HelpReplies: 1Last Post: 01-27-2011, 04:15 PM -
My fourth gear is mest up wat can it be?
By LS1IVANSS in forum Manual TransmissionReplies: 2Last Post: 10-10-2008, 06:40 AM -
what do u guys think about the Meziere water pump
By Frankthetank in forum Southern MembersReplies: 12Last Post: 11-20-2006, 06:22 PM -
I Need A Powersteering Pump Pulley
By Chris2001SS in forum Parts Wanted / TradeReplies: 0Last Post: 09-16-2006, 06:19 AM
