Thread: LS1 Fuel upgrade
02-14-2007, 03:01 AM #1
- Aug 2006
- Sandbox, Kuwait
Black- 06 Chevy Caprice HT (RIP)
LS1 Fuel upgrade
Good day to all....
On a good note i have my sweetheart purrin and runnin strong at the moment.
My question is, i have a FAST fuel rails, i will be gettin new injectors, but i need the accessories to complete the kit...Does anyone know of a kit that is purely plug and play, where i get all the little details, like the plug adaptor for the stock output, the non returnin fuel regulator and cross over hose...
Lookin forward to your replies
Naf
02-14-2007, 03:58 AM #2
- Retired Outlaw Sum Bitch
You again LOL....I went with the 255 Walboro pump...replaced the hose from the tank ( The factory sucked...very restrictive) did the bucket mod...I maintain 62lbs of pressure at the fuel rails throughout the RPM range....
Hoses just came from NAPA w/AN fittings...and we used the Ford injectors....it was plug and play..
02-14-2007, 04:11 AM #3
- Aug 2006
- Sandbox, Kuwait
Yes i am like your mother in law, i pop up when you least expect it....
Anyways, what about the fuel regulator? Or you went without one?
As for the fuel pump, i dont know if i wanna fool around with it...I have heard many scary stories where ther pump failed and thus the engine as well...
03-05-2007, 01:40 AM #4
Well even if your not going to replace pump you NEED to replace feed line as it is factory kinked from assembly line.
On the regulator tip......... It's regulated inside of the stupid bucket. You can regulate up front but that would require you to run a return line back to the tank. Which is posiable and know of people doing it but you'll also need someone to boost the pressure setting in the pcm. If you go that route MANY companies offer a universal return regulator. That just limits the return enough to keep pressure where you want it. Hope I helped.
The fitting you need for the pressure line coming off the firewall is made by Russel-Part #640850 available from Summit or Jegs every now and then. It makes the line come off with a male -6 AN fitting for your hose end going to rail. There has been time periods where on back order for a month or two.Don't be afraid of the bottle!!! Be afraid of your tune!!!
03-05-2007, 02:07 AM #5
- Aug 2006
- Sandbox, Kuwait
That is odd, i found that there is a non return reg on my stock lines...
I hate GM, they make things so complicated when they could be so simple...
Thanx for the help though, i will keep you posted on my progress
03-05-2007, 07:56 AM #6
If we see that on the evening news, we'll know your progress
03-05-2007, 08:39 PM #7
- Aug 2006
- Sandbox, Kuwait
Hmm, i dont think a tank of gas can get that much of a mushroom...
03-05-2007, 08:53 PM #8
03-05-2007, 08:59 PM #9
- Aug 2006
- Sandbox, Kuwait
So Wade,
We all are starting to see you idealize me...Why the sudden interest?
03-05-2007, 09:05 PM #10
Idolize? Nah. I just like reading about your mods. You're one of the more active posters here, but if it bothers you so be it. I'll add you to my ignore list.
03-05-2007, 09:09 PM #11
- Aug 2006
- Sandbox, Kuwait
By all means, i enjoy the spot light...
03-05-2007, 09:11 PM #12
- Aug 2006
- Sandbox, Kuwait
Hey Wade
What mods have you done to your goat?
When to upgrade fuel system
By 1998 T/A in forum Internal EngineReplies: 13Last Post: 02-18-2015, 10:52 PM -
Question: Fuel Pump Upgrade
By travs98ls1 in forum Firebird / WS6Replies: 3Last Post: 07-14-2010, 01:40 PM -
Question: fuel upgrade
By mark21742 in forum General HelpReplies: 4Last Post: 02-05-2010, 07:22 AM -
Fuel system upgrade
By Naf in forum GM TrucksReplies: 0Last Post: 07-07-2007, 06:27 AM -
LS6 Fuel line upgrade
By Naf in forum Domestics and ForeignsReplies: 1Last Post: 05-01-2007, 11:21 PM
