Results 1 to 20 of 25
Thread: shift kit good or bad trans go
03-10-2008, 07:18 PM #1
shift kits are they good or bad for the tranny does it help the life of the trans or is it bad
03-10-2008, 07:44 PM #2
03-10-2008, 11:10 PM #3
- Jun 2006
- Calimesa, California
How many miles on the unit? What is the condition is the fluid? What torque converter are you running here? What rear end gear ratio? Anything done to the motor? If everything is in good working order, then the "modified" TransGo Performance Shift kit is the way to go to improve durability. It offers smooth part throttle shifts, and firm WOT shifts.
03-10-2008, 11:14 PM #4
03-11-2008, 12:06 AM #5
03-11-2008, 09:44 PM #6
- Jun 2006
If this is for the 1999, then I would go with the TransGo Shift kit with aluminum accumulator pistons, hardened and oem pins. They go for $117.64. If you are going to do this yourself without any help, then it will take the better part of a day. You will need solvent, blue shop towels, air, inch pound torque wrench, drill, files, normal hand tools, etc.
03-11-2008, 10:15 PM #7
what shift kit do you guys recommend for a 2002 ws6?
03-11-2008, 11:21 PM #8
- Jun 2006
The same kit, just maybe different separator plate hole sizes. That can depend on the torque converter you are running, which diameter and stall, rear end gear ratio, and how you drive, what has been done to the motor, etc.
03-17-2008, 06:08 PM #9
Another vote for the Transgo shift kit, with the increased line pressure you will have to address the Torque Management system on the 01 & 02 models.
SteveC
03-18-2008, 02:06 PM #10
I just installed a Transgo shift kit on my tranny, I'll tell you the results once I get it all back together.
03-20-2008, 12:14 PM #11
So, in general, everyone votes for the Transgo shift kit for my car?
03-23-2008, 06:45 PM #12
I definitely recommend the trans go shift kit, made a big difference, shifts are quicker and have less hesitation.
03-25-2008, 08:51 AM #13
what about a 98? pro built automatics?
03-26-2008, 11:45 AM #14
- Jun 2006
Yes, the modified one will do fine.
03-27-2008, 08:27 AM #15
how do i have to modify it?
04-18-2008, 05:35 PM #16
- Mar 2008
- Arkansas
Red- 2002 Z-28
Hey Guys. Wanting to do the same thing to my 2002 Z-28. Car is stock with the exception of an SLP lid. So is the Trans Go the best for my application? And who has the best prices?
05-15-2008, 07:04 PM #17
05-15-2008, 07:57 PM #18
05-15-2008, 07:59 PM #19
Why not just use a hand-held and program for firmer shifts & not have to drop the trans. pan or get your pinkie's all greasey ?
05-17-2008, 02:28 PM #20
- Jan 2008
- texas
White- 99Trans am
Question: What are good shift points?
By JoshuaGrooms83 in forum Automatic TransmissionReplies: 20Last Post: 09-02-2008, 02:15 PM -
Shift Kits Good or bad?
By Street Fighter in forum DrivetrainReplies: 18Last Post: 01-17-2007, 09:45 AM -
where to get a good shift knob?
By ls1kid20 in forum Appearance SectionReplies: 12Last Post: 04-24-2006, 06:50 PM -
Is a shift kit bad or good for my TA?
By Street Fighter in forum DrivetrainReplies: 0Last Post: 04-20-2006, 03:21 AM -
Looking for a good shift kit.
By timmyvws6 in forum Automatic TransmissionReplies: 5Last Post: 01-18-2006, 12:47 PM
