09-20-2011, 12:17 AM #1
- Nov 2010
- The Woodlands,Texas...N.O.
Pewter Metallic- 2000 Pontiac Trans Am WS6
Problems With Aftermarket Sail Panel Speakers (4Th Gens)
Have any of you guys ever have sound problems with aftermarket sail panel speakers in your 4th gen Camaro or Firebird,i hooked up two brand new Sony speakers in my cousins 2000 T/A,but the sound from the speakers are very low,i can feel & see the speakers moving but they play very low
09-20-2011, 04:01 AM #2
Stock head unit? Monsoon? If so, the stock speakers are dual voice coil and there are very few choices for aftermarket replacements.
09-20-2011, 09:19 AM #3
09-20-2011, 11:19 PM #4
09-20-2011, 11:21 PM #5
09-21-2011, 05:16 AM #6
- Jun 2011
- Branchville, NJ
Call Crutchfield and ask them if the speakers are compatable. Even if you did not buy from them. They are very nice and they will answer your question.
09-21-2011, 11:05 AM #7
Monsoon system has the dual voicecoil setup, so you should be fine with aftermarket speakers. Could be a polarity issue -- if the positive and negative are reversed, the speaker cone will suck in, rather than push out. Other problem could be impedance. If you have a high impedance 8 ohm speaker, it will sound quieter than a 4 ohm speaker. The wiring is probably not an issue as you are using a single speaker in place of the stocker on each side. If you were installing multiple speakers on one channel, you can wire in parrallel or series to obtain the desired load for the amp or head unit... that's not your problem though.
09-24-2011, 09:25 AM #8
- Jul 2009
- North of the Motorcity
You can wire a dual voice coil speaker 1 of 2 ways, in series or parallel, which significantly changes the performance depending on the amp.
Found this to save some typing on my end: http://www.stereointegrity.com/docs/DVCwiring.pdfLast edited by KMdef9; 09-24-2011 at 09:27 AM.
10-09-2011, 04:48 AM #9
i think the sail panel speakers in the stock set up were subs.. i had the same low volume from mine when i first hooked them up. just run different speaker wires straight to the head unit..
Sail Panel Speakers
By idle in forum Stereo and ElectronicsReplies: 8Last Post: 08-03-2011, 05:29 PM -
For Sale: Sail Panel Speakers
By Speedy_Gonzales in forum Parts For Sale / TradeReplies: 6Last Post: 08-21-2010, 03:01 AM -
Midbass / Sail Panel Speakers
By benoh in forum Parts For Sale / TradeReplies: 12Last Post: 08-09-2007, 10:56 AM -
what sail panel speakers should i buy???
By TransAmBeast08 in forum Stereo and ElectronicsReplies: 20Last Post: 07-01-2006, 01:10 AM -
Help Aftermarket Sail Panel Speakers Sound Terrible.
By 99BlueTA in forum Stereo and ElectronicsReplies: 4Last Post: 12-18-2005, 08:51 PM
