Thread: Safety
12-11-2006, 05:03 PM #1
Safety
Which is safe to use........ wet or dry 100 shot max.........i read your write up mmrr...... also with a dry where is the best place to put the nozzle your said you only got 65hp on a 100 shot because it was wasnt in the right spot.........im worried about leaning out the motor.......
2002 Chevrolet Camaro Z28 m6
SLP LoudMonth, SLP CAI, SLP MAF, Hotchkis SFC
12.76 @109 1.96-60ft
12-11-2006, 06:22 PM #2
it would need to be about 2" closer. both are safe. i've ran both numerous times. i still prefer wet.
12-11-2006, 06:46 PM #3
do i need a purge for a wet kit
12-11-2006, 06:49 PM #4
the purge is used to get air out of the lines when you first hook up a fresh filled bottle. after that, it is used to get liquid nitrous up to the solenoid.
to get the most out of either dry or wet, you should have a purge kit and bottle heater. when i first started using nitrous, i would purge into the motor during the burnout. just a quick 1 second hit, while heating up the tires.
12-19-2006, 04:29 PM #5
If your worried spend the extra money and get a wet system not a cheese ball dry kit.
You'll actually better off ALL the way around with a wet kit.
Put a Hobbs switch on the fuel side and if you loose fuel press beyond that set point it will cut power to the solinoids so NO MELT DOWNS!!!!Don't be afraid of the bottle!!! Be afraid of your tune!!!
Teenagers and Gun Safety
By Ed Blown Vert in forum Gun's & AmmoReplies: 0Last Post: 04-02-2012, 05:20 PM -
Question: safety light
By wickedbeast in forum Firebird / WS6Replies: 7Last Post: 03-08-2009, 03:01 AM -
safety item ?s
By oreowizard in forum NitrousReplies: 16Last Post: 11-30-2007, 05:38 PM -
What do you think about this safety cage?
By pecha in forum Almost Anything GoesReplies: 7Last Post: 06-15-2007, 07:56 AM -
Gun Safety
By amon37 in forum Almost Anything GoesReplies: 4Last Post: 12-07-2006, 04:27 PM
