Results 1 to 20 of 31
Thread: is this streetable for a cam
03-13-2006, 05:49 PM #1
- Jan 2006
- greenville sc
white- 02
comp cam 236/242 .598/.610 114+4 on a 02 camaro ss
03-13-2006, 06:28 PM #2
- Dec 2002
- n/w chicago
not really.
a few bolt ons, 379 rwhp
11.96 @113.25
03-13-2006, 08:39 PM #3BloonessGuest
Ive found my comp cam 224/228 112lsa a nice everyday cam
03-14-2006, 03:32 AM #4
- Jan 2006
- greenville sc
white- 02
Originally Posted by nhraformula
114 isnt choppy, what would not make it a good choice?
03-14-2006, 05:19 AM #5
- Feb 2006
- australia
red- 03 vy2 holden ls1 ute
Originally Posted by Blooness
03-14-2006, 06:24 AM #6
- Commerce Ga
Black, Blue- 07 TBSS, 07 GSXR1000
232/234 595/598 112 lsa is not too bad for daily driving.
3 inch Chambered Catback.
03-14-2006, 02:05 PM #7
- Jan 2006
- greenville sc
white- 02
Originally Posted by BIG D's SS
03-14-2006, 03:04 PM #8Originally Posted by cjg454ss
Do you mean streetable as in daily driver or weekend toy? Also, are you and M6 or A4?
If you have an auto, you'll want a healthy stall to make that cam work properly without fighting you at every stop light. How streetable that cam is depends mostly on the skills and patience of your tuner.Hammer - hammertime.us
2001 Light Pewter Metallic Camaro SS, 6 speed
K&N, SLP Lid, SLP y-pipe, GMMG cat-back, Lou's Short Stick - more to come!
03-14-2006, 03:09 PM #9Originally Posted by cjg454ss
DUR @ .004" 284*/284*
DUR @ .050" 216*/222*
LIFT .531/.531
OVERLAP 56*
LSA 114*
DUR @ .004" 286*/ 290*
DUR @ .050" 224*/ 228*
LIFT .551/.551
OVERLAP 55*
LSA 116*
for giggles, here's a sound clip of this cam in a 408 motor
DUR @ .004" 290*/ 294*
DUR @ .050" 228*/ 232*
LIFT .551 / .551
OVERLAP 68*
LSA 112*
here's what happens when you go from a 112 LSA to a 114 LSA given same duration numbers. it changes the overlap by 4*.
DUR @ .004" 272*/280*
DUR @ .050" 210*/218*
LIFT .531/.531
OVERLAP 48*
LSA 114*
LIFT .531 / .531
OVERLAP 52*
LSA 112*Cold Air Intake, Muffler Delete, Vinci High Performance Dual Valve Springs, Hardened Pushrods, Yella Terra 1.85 Rockers, Some Hydropdipped Stuff, Strut Tower Brace, Some SS Badges, boost/vacuum gauge, fuel pressure gauge, some checkered stripes, drilled/slotted rotors, ZL1addons Stealth wickerbill, Ruxifey LED side markers
03-14-2006, 03:16 PM #10Originally Posted by cjg454ss
03-14-2006, 03:24 PM #11
- Sep 2005
- Pueblo, Colorado
Black- 1998 Pontiac Trans Am
Depends what you consider streetable. I would highly recommend trying to find some people with cammed ls1s and have them take you for a ride.
personally, thats a bit too radical for my tastes.
03-14-2006, 05:55 PM #12Originally Posted by mrr23
Advancing the cam should help it gain back a bit of its low end, but as others have stated, it is still a bit on the wild side.
03-15-2006, 06:23 PM #13
ah, i was having a blonde moment.
03-16-2006, 07:19 PM #14
- United States
Red- 1998 Cherokee Classic
My cam is....236 / 240 601 / 608 114 + 4 Comp Cams XER
Stock heads, stock valves, stock rockers....Manley Nextek Dual Springs.
M6
It is a very streetable cam.
03-16-2006, 07:27 PM #15
- Thornton, CO
Originally Posted by Blown 98 Z
But your idea of a streetable car is a full-out drag car on street tires.
Streetable is all perception.
Daily driver material is also one to look at.
I am running a 248/254 629/622 113 in mine.
Streetable...yes.
Daily driver material...no.
03-18-2006, 11:34 AM #16Originally Posted by hammertime
03-18-2006, 02:44 PM #17
BIGGER ISN'T ALWAYS BETTER.
-Will
03-18-2006, 02:51 PM #18Originally Posted by TARZAN
03-19-2006, 06:29 AM #19
- Jan 2006
- greenville sc
white- 02
is the +4 any good, also how would this work in a blower or turbo setup
03-19-2006, 08:33 AM #20Originally Posted by cjg454ss
Help: TSP Setup is this streetable
By Eganslp in forum Internal EngineReplies: 17Last Post: 11-13-2010, 06:58 PM -
550+ rw streetable hp out of a 383 ls1 N/A ?
By djdilliodon in forum Internal EngineReplies: 40Last Post: 11-11-2010, 12:48 PM -
Question: 2001 5.3, is this Cam Streetable?
By FORD RECOVERY EXPERT in forum Internal EngineReplies: 5Last Post: 11-08-2009, 11:43 AM -
Is this streetable?
By stangslayer98 in forum Internal EngineReplies: 11Last Post: 06-18-2008, 07:56 AM -
Streetable HP
By Phlash_riot in forum Almost Anything GoesReplies: 1Last Post: 01-19-2007, 10:27 AM
