Results 1 to 20 of 28
Thread: BBK header question
03-12-2008, 08:45 PM #1
BBK header question
i have a 96 trans am lt1, and my buddy has some bbk headers off his 95 lt1 camaro, would they fit my trans am? i think he said he had 2 bolts the bolts them to the y pipe on each side, and i think m y pipe has 3 bolts, not sure though? but if u know anything about it please let me know!! thanks
also with going bbk header, with a magna flow high flow cats and borla cat back exhauset would it sound better and performance? i have stock manifolds with magna flow y pipe and borla cat back, what would be the difference adding short bbk headers on them?
03-12-2008, 08:48 PM #2
03-12-2008, 09:17 PM #3
where would i get the pacesetter lt and y pipe at? my car is pretty low already!! so it will not work on my car then?
03-12-2008, 09:23 PM #4
03-12-2008, 09:34 PM #5
03-12-2008, 09:42 PM #6
03-12-2008, 09:45 PM #7
03-12-2008, 09:49 PM #8
03-12-2008, 10:03 PM #9
Look into midlengths if clearance is major concern. A good 1 3/4 primary midlength (such as AS&M) will get the same gains as long tubes, with no loss in clearance. Long tubes are overrated for 99.9% of applications.
03-13-2008, 10:33 AM #10
Ok here's the deal, I got a 96 trans am with a ypipe and 2 cats obd2 correct !!well his is a 95 with aypipe and one cat which is gutted and obd1 ok! Well he is going to give me his ypipe so his bbk shortys will fit!! So using his ypipe with one gutted cat and the bbk headers wouldn't that woork? Cause I cannot use my y pipe on the bbk's cause they are made to fit his ypipe which is obd1 and mine isn't , so. Wouldn't that work like that or what?
03-13-2008, 10:43 AM #11
Ok and aother question! If I put the shorty bbk ceramic coated headers with his y pipe with gutted cat, and my borla cat back exhaust, how would that sound and would I get any performance differnce from what I have now , factory exhaust manifolds, magna flow high flow cats y pipe and the borla cat back?
03-13-2008, 10:48 AM #12
- Nov 2005
- Fontana, Ca.
Black/Black- 96 Vert Z28-RIP/94 TT Z28
I wouldn't waste any money or time on shorty's, unless your getting them for free.
03-13-2008, 12:36 PM #13
Ok well I don't have much I can spend right now, and I need the I pipe that connects to my y pipe and goes back to my muffler and for 150 dollars he is giving me his gutted cat y pipe, bbk ceramic coated headers, the I pipe I need, 36lb accel fuel injectors, a de screened MAF, and some trim pieces I need? Now is that a good deal or0not? Honestly? He is guttin his camaro and trans am , so let me know what yall think !! I am trying to make a decision here quick!
03-13-2008, 01:25 PM #14
- Nov 2005
- Fontana, Ca.
Sounds pretty good then, but you'll need a tune with those 36lb injectors. Good price though cause I bought my 30lb. Accel injectors new for like $200. The de-screened MAF you can just do in like 10 minutes but the other stuff sounds good for $150.00. You could even sell the injectors and make some of your money back, 36lb. injectors is pretty big for a stock engine.
03-13-2008, 05:28 PM #15
yes but i am not sure if u wanna put the shorty's bbk on or not!! i am waiting on a guy to call me back with edelbrock mids with x pipe and bullet glass packs dump i really want that
03-13-2008, 06:49 PM #16
- Nov 2005
- Fontana, Ca.
Not sure if it's the same for the mid-lengths but a friend of mine who owns a performance shop told me the shorty edelbrocks have a lot of underhood engine noise because the tubing wall thickness is too thin. Just something you might want to check out.
03-13-2008, 07:29 PM #17
03-14-2008, 05:25 AM #18
So what do yall think I should do? Do u think I should put the bbk shortys on or is it a waste of time? What would the sound be like with shortys, gutted y pipe and borla cat back?
03-14-2008, 12:56 PM #19
03-14-2008, 09:12 PM #20
Ok , so a good loud or shity loud? I like it loud I have a ypipe on right now with high flow cats and exhaust manifolds, and it pretty loud, so would it be louder than that with bbk shortys gutted cat and my borla cat back on?
once again a header question
By bmwmteam in forum External EngineReplies: 5Last Post: 05-04-2009, 06:46 PM -
Header question
By LETHALxLS1 in forum External EngineReplies: 238Last Post: 01-24-2008, 05:33 AM -
Header Question
By garver in forum External EngineReplies: 5Last Post: 11-11-2007, 05:25 PM -
Header Question
By fastfirebird2002 in forum External EngineReplies: 1Last Post: 05-21-2007, 03:12 PM -
Header Question
By TransAm45 in forum LT1Replies: 5Last Post: 01-04-2006, 05:18 AM
