Results 1 to 20 of 23
08-07-2009, 07:08 AM #1
- May 2008
- New Brunswick
Bang for Buck, Heads & Cam selection
Bang for buck wise, what is the best way to go with heads and cam...I'm assuming someone has a package out there for the LS1 (2002) that will come with mostly everything essential if not everything completely that I would want. I just don't know where to look for the best prices, or what heads cam combos have been proven to perform.
But hey, if I can get a better deal picking one component here, one component there, I'm definetly willing to go that route as well. I'm just hoping to learn from others experience here.
08-07-2009, 10:57 AM #2
- Feb 2006
- U. S And A Greatest country in all of world
Stock- 2002 Camaro
how much you have to spend?
08-08-2009, 06:28 AM #3
Texas Speed's PRC heads and cam kits.
08-08-2009, 10:14 PM #4
Im with the Dr. depends on how much you have to spend
08-09-2009, 09:08 AM #5
- May 2008
- New Brunswick
Budget wise...I will find what I have to somehow. But basically every $ of it is over budget so cheaper is better, I just don't want anything so ridiculously cheap as to be junk, a little extra $ for a lot more power or realiability etc is always worth it.
08-09-2009, 09:13 AM #6
08-10-2009, 04:20 AM #7
- May 2008
- New Brunswick
I hope they are a HELL OF A LOT better quality than the texas speed catted y-pipe I ordered. That and the pacesetter headers are the only things that I've ever ordered from texas speed and they were so amazingly misfitted I almost had to scrap the damn things and bend up something custom.
08-13-2009, 09:13 PM #8
- Jun 2009
- clifton nj
Light Pewter Metallic- 2002 Camaro Z/28
expensive, but summit offers kits from trickflow, but theyre like $3200. they have most of the stuff you will need. search by engine, chevrolet, 5.7/350, gen III/LS based. other than that, patriot has some kits for around $2K but i hear their porting is terrible. stage 2 ls6 from what i hear is the best way to go. anyone hear of how the 6.o heads work? what other mods would you need to run them? i was thinkin stock 6.0 heads with a good porting job, mill em a bit for compression, and throw some stiffer valvesprings in em. any thoughts?
race it, wreck it, dump some time and cash into it and DO IT AGAIN...
08-13-2009, 09:21 PM #9
There are lots of places that offer good head and cam packages summit, pace performance, alot of kits are expensive but, great performance results. Pacesetter headers are junk by the way just throwing that out there... Don't blame texas speed for that they aren't the only ones that sell them.
08-14-2009, 05:22 AM #10
- May 2008
- New Brunswick
08-14-2009, 01:28 PM #11
Patriot heads are junk, I wouldn't waste my money.
08-19-2009, 09:00 AM #12
- May 2008
- New Brunswick
Ok, so I've looked around a little and price wise I hear decent things about PRC heads for the low $ involved. But I'm still not sure on the technicals, if I'm building a Mid-Range motor that lets me play around autoX and street tracks as well as 1/4mile drag what do I really want in a head? I'm all about the "area under the curve" especially low-mid range RPM as opposed to huge power in the 5500-6800 range (not what I want)
Compression ratio, valve size, cfm of flow, incoming air charge velocity, CC port volume, CC combusion chamber...god I think I need to go take an engine course just to know what I want to look for in a head.
As I said, I hear good things about power increases from PRC heads for the low $ involved but then I also hear trick flow and AFR can make more power down low and under the curve as opposed to PRC being a bit more of a peak # style head. Is there any/much truth to that?
08-19-2009, 02:36 PM #13
Personally I'd want the power up top. This is what wins races. People say cams like mine 232/236 613/613 111'+1 lack low end torque. I haven't noticed at all but no one races between 3,500-5,000 rpms anyway. If you do I'll beat you in a six cylinder car.
08-19-2009, 02:48 PM #14
- Jun 2009
- coon rapids, MN
red- 2000TA
AFR or TFS ,i've seen pictures of the roof of the intake port break open on tsp .
08-19-2009, 03:12 PM #15
- Aug 2009
- riverside
whit- 2008
mice info
08-19-2009, 04:19 PM #16
08-19-2009, 04:21 PM #17
08-19-2009, 05:57 PM #18
- May 2008
- New Brunswick
08-19-2009, 06:10 PM #19
08-19-2009, 06:31 PM #20
- May 2008
- New Brunswick
uh huh...and how do you get to 6K? - by going through 4-5K first. Plus if I'm running the 1/4 I see 4-5k in first, 4-5k again in second, and I finish the 1/4 in the bottom of the 4-5k range of 3rd. The race is over long before I hit 6k in 3rd and I'd have to trap some High speeds to get there. (unless like I said, I used deep gears...and since this is my dd, I'm not going that route)
Besides, I'm about to start autoXing this sept. Most guys run hondas, neons, etc. but the few guys who do run muscle are all saying pretty much the same thing. And that is, that the course is too fast to run in first only and first gets the tail going around too easily if your not delicate off the corners. So most of them are putting it in 2 and running the course without shifting. That lets you hit 6k only in the fastest parts of the course, but your in the 4.5-5K range a lot more often.
Is there a flaw in my logic somewhere??
Help: best bang for the buck
By pewter Z28 in forum Camaro / SSReplies: 18Last Post: 03-30-2011, 04:17 PM -
Best Bang for Buck Kit?
By GottaHaveLS1 in forum NitrousReplies: 4Last Post: 02-12-2011, 10:48 PM -
LS heads Bang for Buck?
By QtrWhore in forum Internal EngineReplies: 61Last Post: 07-14-2008, 08:34 AM -
What heads are the best bang for you buck?
By irocandroll4ws6 in forum Internal EngineReplies: 5Last Post: 09-11-2007, 09:04 PM -
Bang for the buck
By camaro_freak86 in forum GM TrucksReplies: 1Last Post: 08-02-2006, 03:34 PM
