Results 1 to 1 of 1
08-15-2022, 08:00 PM #1
- Sep 2005
- Raleigh, NC
Black- 1998 Pontiac Trans A,
Crank, No Start (no Spark) condition on Trans Am 448
So... my car sat for 4 or 5 years. My friend who built the engine, put it back in (he doesn't live in my town) and I traveled to him to hook up the tranny and trailered it home to put all the accesories on.
I found a couple stacked grounds and hooked up what I could find. Initially i got no cranking at all, but discovered the cluster of wires in the back that terminates into one was broken. I also replaced the old battery and ground cables.
I have a new battery, all fuses and relays are working.
I hear pumps prime (Yes, I have two in the tank). Engine turns over, there is fuel pressure at the rail. Engine cranks, but no start.
I heard terrible grinding noise when starting. I replaced the starter, and that is no longer a problem, (Weak solenoid I guess. I saw where it started to wear flywheel teeth.)
There is no Spark (I checked with in-line Spark Tester)
I Replaced Crank Position Sensor and Water Temperature Sensor.
So, I ran across this video where a Camaro guy describes that the Coil Pack assembly is not grounded creating his Crank/No Start condition:
Here is me troubleshooting that situation on my car, if you want to spend a minute or two to watch me check it:
Question: Should the Valve Covers be grounded? Mine are not.
I did try grounding them like he did his, for a quick check prior to trying to locate where a ground might be loose, and the condition did not change.
Can anyone help me with where i should look for such ground?
If you think it's not grounding situation, can you suggest other things I may look for?
Thanks in advance!
No start condition - 2002 T/A
By joesurfer in forum Firebird / WS6Replies: 4Last Post: 07-15-2019, 11:47 AM -
99 Trans Am WS6 will crank over but not start
By REDVENOM in forum General HelpReplies: 12Last Post: 11-08-2013, 03:36 AM -
p1336 code - crank relearn condition
By 1MileCrash in forum General HelpReplies: 5Last Post: 07-02-2013, 05:41 PM -
no start condition
By Aceshigh22 in forum General HelpReplies: 3Last Post: 02-20-2010, 08:09 AM -
FS: LS6 Intake & LS1/LS6 Crank Like New Condition - SOCAL local pickup only!
By Sandragnx in forum Parts For Sale / TradeReplies: 6Last Post: 08-23-2005, 03:20 PM
