Results 1 to 20 of 104
Thread: Classic Muscle
12-07-2009, 03:12 PM #1
Classic Muscle
So you have some Classic Muscle what is it ?
what have you done to it?
how long have you had it ?
12-09-2009, 07:51 AM #2
- cleveland ohio
trans am 00 ws6- 1998 camaro ss vert
i wouldn't call it a classic yet but i have an 87 monte ss aerocoupe. 1 of 6058. i plan on doing an ls1 swap come spring.
12-09-2009, 09:17 AM #3
Its considered a classic 20 years + is in the category = that is a nice SS i like it better than the now crappy old man monte carlo ss that 87 has bold styling like a womans contour lines
heres a a 88 SS ls1/t56 swap http://www.montecarloss.com/ls1montecarloss/ . I followed a few months back should help you wih your build this spring
12-09-2009, 09:19 AM #4
Heres the full rundown of the cost he did it for
Valve Train
Camshaft kit
MTI B1
(221/221 .558/.558 114) w/pushrods & springs
$599.00
Shipping
Shipping cost for camshaft kit
$23.00
Gasket
GM 12559271
Water pump gasket (quantity - 2)
$6.68
Gasket
GM 12558013
Timing chain (front cover) gasket
$7.56
Valve Train Sub Total
$636.24
Induction
Intake Manifold
GM 88894339
ZO6 LS6 intake manifold
$375.00
Gasket
GM 12533587
Intake manifold gasket set
$30.00
Throttle Body
Shaner S2
Custom ported Throttle Body
$139.00
Shipping
Shipping cost for Throttle Body
$20.00
Gasket
GM 12552542
Throttle Body gasket
$11.89
MAF
GM 25318411
85mm Mass Air Flow sensor w/built-in IAT
$87.00
Wire Adapter
PAC5889
Jim Pace 3 wire to 5 wire MAF harness adapter
$38.95
Regulator
BPP100-207
Adjustable Fuel Pressure Regulator w/shipping
$113.99
Fuel Injectors
M9593B302
30# SVO fuel injectors
$227.90
Cylinder Heads
MTI Stage II
Fully ported LS1 stage II heads w/2.055”/1.60” valves
$2000.00
Shipping
Shipping cost for cylinder heads
$50.00
Gasket
GM 12498543
Cylinder head gasket set
$34.15
Bolts
GM 12498545
Replacement cylinder head bolt set
$33.76
Shipping
Shipping cost for gasket/bolt set
$11.78
Induction Sub Total
$3,173.42
Crank Pulley/belt drive
Crank Pulley
ASP948500
25% Reduction crank pulley
$164.99
Drive belt
KO60760
30mm shorter drive belt
$25.00
Bolt
GM 12557840
New crank pulley bolt
$3.04
Gasket
GM 12561244
Timing chain (front cover) crankshaft seal
$12.56
Pulley
Tensioner Pulley
$58.00
Crank/belt Sub Total
$263.59
Exhaust Headers
Header Flanges
GM 12480130
LS1 exhaust flanges (quantity – 2)
$34.00
Misc. Bends
MB187
Schoenfeld misc. 1-7/8” 18 gauge pipe bends
$89.95
Misc. Bends
017516U
Schoenfeld 180° 1-3/4” 16 gauge u-bends
$42.00
Shipping
Shipping cost for 18 & 16 GA pipe bends
$35.21
Misc. Bends
1-3/4” 180° 16 gauge u-bend
$14.69
Merge Collector
C-PM178
S&S Headers Inc. 2-3/4” to 3-1/2” merge collectors (2)
$148.49
Flanges
Custom made collector/exhaust flanges (quantity - 2)
$19.04
O2 Sensor Bung
HLY-534-49
Holley O2 weld-in bungs (quantity - 4)
$21.65
Reducer
Dr. Gas 3-1/2” to 2-3/4” reducer (quantity - 2)
$35.26
Welding
Welding supplies (TIG rental, gas, welding rod)
$201.28
Welding Labor
Approximately 10 hours welding (66 full circle welds)
$200.00
Coating
Jet-Hot 2000 Ceramic coating
$234.80
Exhaust Headers Sub Tot
$1,076.37
Exhaust System
Misc. Bends
3” & 3-1/2” 90° bends
$198.66
Reducers
3-1/2” OD to 3” ID reducers (quantity - 4)
$52.00
Junction
3-1/2” to 3” Dr. Gas “X” pipe
$154.34
Gaskets
MRG1209
Mr. Gasket 4 bolt header flange gaskets
$12.97
Misc. Pipe
3” & 3-1/2” pipe sections
$87.65
Flanges
Custom made 4 bolt flanges (quantity - 8)
$76.16
Mufflers
17792
DynoMax Super Turbo (quantity - 2)
$124.00
Converters
93009
Carsound 3” diameter Catalytic Converters
$202.00
Tailpipes
Torque Tech 3” diameter GM G-body GN exit tailpipes
$207.84
Coating
Performance Coatings ceramic coating of head pipe
$105.26
Misc. bolts/nuts
Misc. 10mm bolts and flange nuts (quantity 16 ea.)
$16.13
Plug
18mm x 1.5 bolt for O2 plug
$3.13
O2 Sensor Bung
HLY-534-49
Holley O2 weld-in bungs (quantity - 2)
$10.83
Exhaust System Sub Total
$1,250.97
Transmission
Shifter
PRO 5.0
Shifter for T56 w/shipping
$169.00
Software
Diagnostic
AT1
B&B AUTOTAP diagnostic software
$260.98
Programming
LS1_Edit PCM software (Share price w/3 licenses)
$275.00
Software Sub Total
$535.98
Phase II Mod Total
$7,105.57
Phase I Installation Total
$9,023.16
Total Project PI & PII
$16,128.73
12-09-2009, 11:35 AM #5
- cleveland ohio
that's john b's old right he now has a 427 ls7 in his. i like that write up. i am still thinking of going carbed to save a lot of time and money.
12-10-2009, 02:50 AM #6
- May 2009
- college station, tx
sold: 1999 firebird- 1998 Trans Am
had a 71 plymouth duster for a few days
12-10-2009, 03:50 AM #7
- Jun 2009
- Hollywood, Florida by way of Da' Burgh
Impulse Blurr- 2004 GTO
I had a 70 firebird with a powerglide but I ditched that and got a 73 LeMans Sport with a 400 and I loved that car! It was black and looked mean. Don't ask me for specifics (this was WAY back in 1983) but I remember I put a 540 (I believe) lift Crane Cam in it with a Performer dual plane mid-rise manifold and a Holly 750cfm carb with mechanical secondaries. Black Jack long tubes and a B&M trans pack/shift kit. I was in auto tech school engine rebuilding class and was making good money for being 17 years old ($250 a week LOL!) Me and my classmates did all of the work under the supervision of my instructor from the crankshaft out. Balanced the rods and pistons, shaved the heads ect. That thing was a torque monster! And big as a battleship . . . I sold it when I went on the Aircraft Carrier after graduation.
12-10-2009, 05:41 AM #8
really whats his sn on here ?I would go for the carbed to.tune it yourself are u goin with the t56 or the auto ?
Classic muscle is the only way to go i bet you watch out for carving the canyons on stock suspension haha.
Those Lemans are awesome machines of power, torque and the will to keep on going after beating the snot out of them. How long did you have it ?Last edited by 402 Guru; 12-10-2009 at 05:49 AM. Reason: auto
12-10-2009, 06:19 AM #9
- Feb 2008
- NEW JERSEY
PEWTER- 2001 TRANS AM WS6
My dads got a 66 gto that he has had since the 70's
I had a supercharged 89 formula it was a super fun car but not clasic
oh and I just got my grandmothers 82 sky lark
12-10-2009, 11:53 AM #10
- Jun 2009
I only had it for 2 years. I went into the Navy after highschool and sold it to a buddy of mine cuz it made no sense to me to carry insurance on a car that was gonna sit while I was out of the country for 6+ months at a time. Insurance is big $$$ when you are that young and on military wages.
I live in South Florida, the closest thing we have to a canyon road is a highway off ramp LOL! When I was in Pennsylvania I had an IROC Daytona but the roads there are terrible and the suspension took a real beating. Thank god my dad owned the Dodge dealership, it really saved my ass on repairs. I tore up all kinds of control arms and I cracked 2 rims on pot-holes.
I love the 04' GTO that I have now. I put a Harrop sport differential mount and a full Pedders bushing kit in it about a month ago and this thing grips like a SOB now. If only I could find a twisty back country road to actually take a turn on! I might drive it up up to Lewisville North Carolina some day and visit my buddy, they've got plenty of twistys up there.Last edited by Goat-E; 12-10-2009 at 11:58 AM.
12-10-2009, 11:56 AM #11
- Jun 2009
- Saint Louis, MO
Arctic White & Black- '98 WS6 M6 - SWAPTIME!
I have a '72 Camaro SS that I had originally put in a 383 Stroker with forged internals and nitrous (hate that crap)
now that I'm selling it, it has a brand new 350 in it.
Nothin super exciting, but it's a neat looking car
12-11-2009, 05:11 AM #12
12-12-2009, 07:31 PM #13
yes thats understandable im inlisted in the airforce and have alought of free time on my hands so recently i have not been able to drive my car and it sucks but i know when i get home i get to drive the hell out of my car till the wheels fall off after all the work i put into it i figure theres no way in hell i'll ever sell mine . If you want( for a x-mas gift to yourself theres sales everywhere) to take some corners off the freeway rams like Powersliding or faint drifting then get a bigger sway bar when u go cross country and you will thank yourself that u added it
Yeah i dislike nitrous with a passion( my wife likes to use it though) after my drag racing days i buit a 9.5 nitrous ls1 then rebuilt the sob after 15 runs because i kept trying to break records but my bank got broken insteadlol the 72 ss is a Sick example of american muscle
Sounds sick i don't preferably like ls1.com they think that they are invincible where people on here are friendly when they are just like everyone else thats why i think this site Rocks and are Moderators rocki'll check that build out it looks interesting
what kind of a stall did he go with ?
12-12-2009, 07:36 PM #14
its not muscle but i have a 1921 model t truck havnt seen one like it fully restored inline 4 max of 17mph wooot had it for 10 years...
oh yeah cant for get i got a 69 camaro ss with a 383 stroker still in work tho for the last 18 years lol
12-12-2009, 07:37 PM #15
Until the Trans Am, our fun cars were all old school: '74 Corvette L-82, '70 Cutlass W-31, '67 Cutlass with a 330, and three '66 Buicks which will be combined to build one Wildcat convertible motivated by a 401 Nailhead, with a 340 as a backup motor.
12-12-2009, 07:53 PM #16
cool man got pics ? the 402 nailhead's were one of a kind engines that i will never forget the sound of a camed 401 hearing every cylinder hit at the same time quite amazing indeed how long did it take to finish sir ?
Thats sick a model T truck do u take it to the parades downtown in vegas that they have every year on st. patricks day or something . u shoulds post up some pics of the 69 SS what all have u done to it? what needs to be done to it ?Last edited by 402 Guru; 12-12-2009 at 07:56 PM. Reason: spelling
12-12-2009, 08:01 PM #17
no not in vegas i enter it in shows back in wisconsin tho and all the ss needs is interior and a new trans cuz my mom blew it up this summer not to much done with it tho started as a restore and got a great deal on a 383 stroker from a friend holly carb aluminum race heads edlebrock intake hooker headers with flowmaster cans 9in rear and 373 gears just put on the back bunner till i get outa the military and back to wisconsin but ill see if i can get sum pics
12-13-2009, 05:04 AM #18
This is the original Wildcat: http://www.ls1.com/forums/showthread.php?t=117428 I have the entire chassis, engine and driveline completed setting next to it. The restoration originally started out with a '66 LeSabre convertible -- hence the 340 engine. In searching for impossible to find parts, a gentleman in Virginia sold me a 4 door LeSabre and the Wildcat. In the interim, I had started the restoration on the Corvette, which is completed, and the W-31, which the chassis is completed.
12-13-2009, 05:16 AM #19
- Sep 2005
- hopewell jct, ny
black 01 red 73- 01 z28 and 73 z28
73 R/S Z 28 completly stock
12-13-2009, 08:12 AM #20
that is sick man
can u take some pictures? frame off restorations are the real car builders Dream with all the blood,sweat and tears that go into it they make your lifetime feel like you have accomplished your life goals Congratulations man !
that is a nice looking 2nd get i like the colors is that a vinal top or 2 tone cant tell . good quality pictures' of the z'sLast edited by 402 Guru; 12-13-2009 at 08:16 AM.
Muscle Car Classic - Contrasts
By Ed Blown Vert in forum GTOReplies: 0Last Post: 01-12-2015, 11:31 PM -
US Marshal's classic muscle car auction officially in the bo
By Ed Blown Vert in forum General Help - 5th GenReplies: 1Last Post: 09-25-2014, 06:11 AM -
Semi-Classic Muscle...
By NightRyda805 in forum Classic MuscleReplies: 12Last Post: 08-15-2007, 06:06 AM -
Guys with classic muscle car knowledge, I have a question.
By Murder after Midnight in forum Almost Anything GoesReplies: 11Last Post: 03-06-2007, 06:41 PM -
Classic muscle backwards?
By Glenn in forum Classic MuscleReplies: 1Last Post: 11-01-2006, 06:59 AM
