Results 1 to 15 of 15
Thread: Annoyed
11-14-2009, 05:54 AM #1
Annoyed
I am annoyed i have a high pitch squeak coming from the back of my car it is in the interior for fact but cant find it. Only occurs while the car is moving almost like plastic on plastic or a speed clip on the body rubbing idk im lost and its gets annoying while riding down the road.
11-14-2009, 05:57 AM #2
If thats the only noise you have in your Trans Am, you're doing better than most
-Will
11-14-2009, 06:00 AM #3
- Jan 2009
- North Jersey
Have you checked your spare to see if it's loose in the storage compartment?
11-14-2009, 06:16 AM #4
- Nov 2008
- harrisburg pa.
black- 02 vette vert
if you find it let me know. mine is more like a medium chirp, but it's inside in the back. i pulled the spare, jack and everything out, still does it. one thing i haven't tried though is putting a dab of grease on the plastic bump stops that the hatch rests on when it's closed. the chirp can't be duplicated by hitting, pounding, shaking or anything while the car is sitting still.
11-14-2009, 06:20 AM #5
11-14-2009, 06:32 AM #6
the one thing i did notice is the center plate between the tail lights made a squeak about the same as the one i hear. I grabbed it and gently put pressure on it and sounds almost the same i took the tail light off and put elc. tape where the plastic studs went through and it went away for couple minutes then it came back.
11-14-2009, 06:40 AM #7
11-14-2009, 06:53 AM #8
11-14-2009, 06:53 AM #9
i will do once i get my first paycheck from the new job. Ive been out of work for two months now.
11-14-2009, 08:48 AM #10
whatever you do dont drop loose change anywhere in your 4th gen. you will hear coins rattling for the rest of your life.
11-14-2009, 09:29 AM #11
Everthing rattles in a turd gen
To the OP, check the spare as has been stated. The "trick" I use is to blackmagic the spare. Also check the bump stops on the hatch for proper adjustment. If they are not properly pushing against the hatch when it's closed, the latch were it hooks to the "loop" on the body can sqweek too.. So can the hatch bump stops where they rest against the hatch..Last edited by Smittro; 11-14-2009 at 11:00 AM. Reason: spelling as usual
11-14-2009, 09:31 AM #12
11-14-2009, 10:20 AM #13
- May 2007
- Davenport, Iowa
Bright Red- 1999 Trans Am Ws6
I fixed all the rattles, and my rear end barley whines as long as that board is up against the hatch. I do however have a clunk when I hit bumps, it goes away after driving a while though. I just crank my stereo up to cover the noise till then.
11-14-2009, 04:22 PM #14
- Sep 2007
- Philly+Glenmoore, Pa
11-14-2009, 05:42 PM #15
thats the thing i can only hear it when i have my cruise set lol. and most the time i have stero up. But its just one thing id like to stop.
Are you annoyed by people burning rubber?
By apache in forum Almost Anything GoesReplies: 231Last Post: 06-29-2008, 09:35 AM -
i'm annoyed at drivers lately
By 310stanger in forum Almost Anything GoesReplies: 19Last Post: 09-25-2007, 07:57 PM
