Thread: HP Tuners HELP
05-05-2019, 02:46 PM #1
- May 2019
- Church Hill
Blue- 1957 Chevy Truck
HP Tuners HELP
Hey guys I'm new. I need Help!!!
I'm wanting to buy HP Tuners, I have two 5.3 vortec engines, 4l80e transmissions wiring harness computers. What I'm wanting to do is remove the Vats, check codes, cam upgrades, tell it what transmission, and whatever simple stuff I can learn. Keep in mind I want to do this myself to learn and to be able to do my own stuff. Usually this leads to me helping others as well. So, do I need the Pro or Standard? And what else do I need to buy to make everything work. Thanks for any advice.
05-05-2019, 02:48 PM #2
- May 2019
- Church Hill
The 5.3's and transmissions are 2000-2003
05-05-2019, 03:02 PM #3
- Jan 2016
- US
Standard until you are familiar with the system
I believe that the pro gives one the ability to work with wide band O2 sensors also
Sent from my SM-N920P using Tapatalk
05-05-2019, 03:06 PM #4
- May 2019
- Church Hill
Is it the same price to upgrade to pro later? And do I need the VCM editor and VCM scanner? Thanks
05-10-2019, 01:04 PM #5
easier to buy the pro now. it takes awhile for them to modify the module to accept external inputs.
the editor and scanner is the program that comes with the purchase. the editor is what you use to modify the pcm. the scanner is what you use to see what's going on with the engine through the sensor outputs.Cold Air Intake, Muffler Delete, Vinci High Performance Dual Valve Springs, Hardened Pushrods, Yella Terra 1.85 Rockers, Some Hydropdipped Stuff, Strut Tower Brace, Some SS Badges, boost/vacuum gauge, fuel pressure gauge, some checkered stripes, drilled/slotted rotors, ZL1addons Stealth wickerbill, Ruxifey LED side markers
05-10-2019, 01:15 PM #6
- May 2019
- Church Hill
Thank you!! What is the advantages to pro, and should I buy it?
06-03-2019, 02:26 PM #7
- Apr 2010
- Alabama
I have pro and while I can't comment on the specific differences between the two I do know you can go much further with the tuning capabilities than standard. I'd say if all you wanted was to do a little tweaking and scanning then standard would be fine but more than that it makes more sense to go pro. If you want to be able to tune I'd definitely invest in pro and not standard. Fyi they so sell a bench mount so you can tune with the pcm out of the car too. I have it and it works nicely, it is around $150.
Sent from my SM-G960U using Tapatalk1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
10-11-2021, 03:46 PM #8
- Oct 2021
- pa.
use standerd and buy a wide band. you can connect wide band to your laptop usb port.
Looking to buy HP Tuners
By ls1wallen in forum Parts Wanted / TradeReplies: 0Last Post: 11-06-2011, 12:05 AM -
hp tuners
By joejenkinsglass in forum Parts Wanted / TradeReplies: 0Last Post: 02-13-2010, 03:06 PM -
Tuners ??
By BDowning in forum Mid-West MembersReplies: 1Last Post: 09-05-2008, 09:35 AM -
tuners for a 98 TA ls1
By 98_Ws6_scooter in forum Computer & TuningReplies: 18Last Post: 10-25-2007, 04:51 PM -
HP Tuners
By rebells6 in forum Parts For Sale / TradeReplies: 1Last Post: 08-13-2006, 04:45 PM
