    Chicago
    Radio not shutting off with driver door 1999
    I have a 99 SS Camaro when I shut the car off the radio and accessory power stays on even when I open the driver door and also dome lighting will not come on when opening door works with passenger door I have to open the passenger door in order for it to shut down I replace the driver door switch and still the same issue oh and it will time out after 10 minutes do you think it’s a BCM problem or what else can I check
    Junior Member liamleque's Avatar
    Apr 2022
    Black metalic
    Audi
    Actually, I think, in this case, you should visit any repair service. First of all, if you can't solve this problem at first, it is better to give an opportunity to professionals.
    Member sjgreen6's Avatar
    Dec 2009
    Mechanicsburg, PA
    Navy Blue
    2002 Trans Am WS6 Conv
    One possibility is that you have the very common bad solder joints in the Body Control Module. When the joints are bad it can cause havoc with the radio, windows, and wipers. This is a known issue with many 4th gens and fairly easy to fix if you are reasonably handy, own a decent solder gun, and can follow directions without soldering your fingers together. Send me a PM with your email address and I will send you a good set of instructions to consider.
    Steve
    Member speedyWS6's Avatar
    Sep 2009
    U.K.
    2002 WS6 TA
    I seem to remember it was a bit of an ordeal to get my BCM out
    when I had some gremlins!
    I hope it is easier in a Camaro!!
  1. Wanted: Driver's side interior door bezel for 1999 Camaro
    By White Knight in forum Parts Wanted / Trade
    Last Post: 11-24-2012, 11:14 PM
  2. Wanted: driver door
    By 98 Trans-am in forum Parts Wanted / Trade
    Last Post: 06-18-2010, 05:52 AM
  3. 98-02 Driver's Door
    By tep98ws6 in forum Parts Wanted / Trade
    Last Post: 11-21-2009, 11:30 PM
  4. 1999 Sebring Driver Door Panel Needed
    By Silverado2000LS1 in forum Almost Anything Goes
    Last Post: 04-17-2009, 05:05 AM
  5. WTB: Driver's door for 02 WS6 T/A
    By 02CETAgirl in forum Parts Wanted / Trade
    Last Post: 07-19-2007, 08:20 AM
