Thread: EGR
10-01-2011, 12:20 PM #1
- Sep 2011
- Orlando
Black- Trans am
EGR
my EGR is not connected. cause i got headers, how can you deleted them
10-01-2011, 12:57 PM #2
Yes, you can disable the codes with editing software. (HP Tuners, EFI Live, etc) Make sure you pull the fuse for the EGR pump.
10-01-2011, 10:44 PM #3
- Sep 2011
- Orlando
Black- Trans am
where is the fuse located?
10-02-2011, 05:00 AM #4
I assume you are removing the egr and the AIR system, so pull the fuse under the hood labled air pump.
10-02-2011, 06:49 PM #5
- Jan 2009
- North Jersey
After you pull the fuse and tune that ride, you should be good to go.
10-02-2011, 07:38 PM #6
- Sep 2011
- Orlando
Black- Trans am
idk where is the fuse located the fuse box. or etc
10-02-2011, 07:59 PM #7
Under the hood...
10-03-2011, 03:40 AM #8
The fuse boxes are behind the drivers head light. Pull the cover, and the diagram is on the bottom. You're looking for the fuse labled "air pump"
10-04-2011, 08:15 AM #9
- Sep 2011
- Orlando
Black- Trans am
ok did that. what i do with the 2 AIR HOOK/EGR HOSES OUT STill
