Thread: new member with problem
09-19-2011, 04:50 AM #1
- Sep 2011
- lenoir city,tn
black- 1996 ws6
Thank you for welcoming me into your community of owners. I come with a problem. I recently bought a 96 ws-6. It seemed to be in great shape,however I have recently incurred a problem..it won't start. Replaced the fuel pump(thought to be the problem) still nothing, it just turns over and no noise from new fuel pump when key is turned on. Any suggestions what to look for? Really frustrated as I just started getting to know this car.
09-19-2011, 05:42 AM #2
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
G'day and welcome. If you can put a fuel pressure guage on it, you should see between 41-47 psi with the ignition on. If you aren't seeing any pressure, I'd start by checking the pump relay, and move on from there.
09-19-2011, 06:42 AM #3
- Sep 2011
- lenoir city,tn
black- 1996 ws6
going to today after work. any advice on moving from relay if it checks out? ...already replaced fuel pump.
09-19-2011, 07:54 AM #4
Recheck the wire harness. Make sure it's grounded. Also the regulator could have gone bad too.
09-19-2011, 08:05 AM #5
- Sep 2011
- lenoir city,tn
black- 1996 ws6
Will mention that to mechanic buddy of mine that is doing the work. We didn't get into anything else after spending most of day with fuel pump replacement...any more advice would be welcomed and thanks for advice now..
09-19-2011, 03:42 PM #6
Welcome!
The engine needs fuel, air and spark to run. Start with the basics and work the problem. Check your fuel pressure while cranking, pull a plug or two and check for spark, inspect your fuses and relays for any blowouts, if there is an aftermarket security system on the car make sure that is not the issue, etc...
09-19-2011, 06:10 PM #7
09-19-2011, 06:33 PM #8
Welcome to the site, Mike! Hope you get it figured out soon so you can get back to the business of getting acquainted with her
Obama's Woman Problem A Problem Of His Own Making
By Ed Blown Vert in forum Political / Debate ForumReplies: 0Last Post: 01-14-2013, 02:50 PM -
3rd member problem ??
By 402 Guru in forum DrivetrainReplies: 16Last Post: 12-01-2009, 11:03 PM -
New Member, has a problem :(
By 69ss99z28 in forum New Member IntroductionsReplies: 4Last Post: 05-19-2008, 06:35 AM -
Fuel Problem or Severe Engine Problem
By pet_monk in forum General HelpReplies: 3Last Post: 02-18-2008, 07:51 AM -
New Member Just bought 98 T/A A4. Tranny Problem?
By frank450r in forum New Member IntroductionsReplies: 3Last Post: 08-02-2007, 07:26 AM
