Results 1 to 14 of 14
Thread: AC Recharge on LT1
06-12-2008, 06:19 AM #1
AC Recharge on LT1
I have a 94 LT1 and My AC Compressor has been making noise, squeaking, since I bought my car. The AC doesnt really work, semi-cool but not cold air. Now I have been told I can "Get a fill kit and 2-3 cans of R134 w/ lube added" to fix this.
So what exactly do I need to pick up and how much (oz's)? I have never messed with a AC system before.
Can anyone help me out with directions on what to do? (pictures would help too) Thanks94 m6 Formula - Sold
2000 NHRA Formula - Always For Sale
06-12-2008, 12:18 PM #2
- Jul 2005
- Jacksonville, FL
Not sure on a complete fill on the LT1, LS1 is 1.5 lbs. Since yours is "semi cool" probably don't need that much. If you want to try charging it get a kit with a low pressure guage and refrigerant with dye in it, so you can look for any leaks if it stops cooling again. Here's a chart for the '95, yours is probably the same. http://shbox.com/1/ac_performance_chart.jpg
06-12-2008, 07:19 PM #3
I know I need to get some R-134a but how much? Do I need a recharge kit? Something like this?: http://www.partsamerica.com/productd...goryCode=3571B
And can anyone help me out with directions on what to do? Which fitting do I put the R-134a in, the one towards the Radiator or the one towards the firewall side? (LT1)
Thanks
06-13-2008, 02:50 AM #4
- Apr 2008
- Madison, WI
The kit will have directions and it'll only fit on one fitting. The compressor squeak is probablly a worn/misadjusted clutch.
Be careful when recharging with those kits. Add too much and it'll ruin your compressor. Getting a kit with a gauge will help prevent that.
06-13-2008, 05:50 AM #5
06-14-2008, 05:06 PM #6
- Apr 2008
- Madison, WI
Well there is supposed to be a .020" gap between the clutch and the pulley.
In the picture from left to right: Clutch, Pulley, magnetic coil
. When the clutch springs get a little worn out, they don't pull the clutch back all the way and it rubs against the pulley.
06-16-2008, 02:15 PM #7
Ok...so the Clutch never engages when I turn on the AC.
I can however turn the clutch by hand.
Will a recharge do any good or is the clutch/compressor done for?
06-16-2008, 03:31 PM #8
- Apr 2008
- Madison, WI
A low charge will cause the clutch not to engage. There are sensors to detect low pressure and they won't allow the clutch to engage.
06-17-2008, 03:57 PM #9
Well I got the recharge kit with the gauge and the 18 oz can filled her to 25 psi. The clutch kicked on and the AC worked.
The squeaking/squeeling goes away too when the clutch is engaged. It comes right back though when the cluth disengages.
06-17-2008, 05:26 PM #10
- Apr 2008
- Madison, WI
25 psi sounds a little bit low and I think when it gets really hot this summer your AC won't work as well, but congrats on the progress.
The pressure should be about 40psi.
06-17-2008, 05:44 PM #11
06-17-2008, 05:53 PM #12
- Apr 2008
- Madison, WI
Take it to a shop and have the clutch gap adjusted. We do that all the time. There is a special tool to pull the clutch out and/or off if a person was gonna replace it.
06-17-2008, 06:30 PM #13
Is there any way to possibly do this myself?
And I was thinking it might be a bearing or something...not sure of construction of the compressor. But I guess it could be that the clutch is too tight to the pulley and is rubbing but I wouldnt think it would make that noise.
Ill see if I can get a video of it tomorrow and youtube it or something.
06-23-2008, 11:29 AM #14
Haha...it appears my AC is Hemorrhaging out the refridgerant. After a few days the psi is back down to 0.
Well not able to get a good vid...audio doesnt pick up the sound real well.
How much for AC recharge, or can it be DIY?
By Naaman in forum General HelpReplies: 14Last Post: 08-06-2011, 03:55 PM -
Question: recharge a/c 2004 gto
By rude_red in forum General HelpReplies: 5Last Post: 06-09-2008, 04:05 PM -
AC recharge and oiling??
By adham in forum General HelpReplies: 17Last Post: 07-17-2007, 03:17 PM -
Recharge A/C
By Tw1st3dSS in forum General HelpReplies: 7Last Post: 05-05-2007, 04:00 PM -
A/C Recharge
By Ed Blown Vert in forum Western MembersReplies: 10Last Post: 09-28-2005, 03:53 PM
